Headlight Correction LIVE Detailing Class - Machine Sanding vs Only Buffing
This is classes #29 since we started these LIVE detailing classes.
29: Headlight Repair - Sanding, Buffing or Both?
Mike and Yancy are back and will be getting to the bottom of headlight repair. Do you need to sand?? Can you just buff with a compound?
The guys will answer this question and help you see the light… Pun intended!
https://youtu.be/sBWJYpn1M7c
We go live in about 15 minutes
Re: Headlight Correction LIVE Detailing Class - Machine Sanding vs Only Buffing
:bump:
Added the after shots...
Did anyone watch this LIVE class?
Like?
Dislike?
Quote:
Originally Posted by
Mike Phillips
Good enough for another 17 years! Im the MAN Im the MAN Im the MAN Im the MAN
It's just another 2 years on the driver's side with the Griot's kit. Remember? :)
After 2 years, is that likely going through the whole process again with resanding or just respraying if it hasn't yellowed?
MisterSnoop
I was thinking more of the BIG PICTURE - in that, these headlights lasted 17 years without ANY maintenance and without any further maintenance it's possible they could "last" another 17 years, I don't mean they would "look good" for another 17 years - they would likely look like they did after the first 17 years - BUT - they were still existing. :D
MisterSnoop
Probably. Rod Kraft from Griot's told me they've seen up to 3 years with their coating but that all comes down to like I aways say about coatings, waxes and sealants, how long ANYTHING lasts depends on how it's "touched" and of course stored.
But yeah, like I stated in the beginning of the video - the FACTORY appearance of the plastic doesn't last forever so nothing "we collectively" spray out of a can, pour out of a bottle, etc. is going to outlast factory orginal resin or "plastic".
I'm looking forward to my next classic Blazer with old school glass headlights. I was off on the $5.00 price I mentioned in the video, they're up to $12.00 now at NAPA. :bolt:
https://www.stockwiseauto.com/images.../WAG/H6024.jpg
:cheers:
Mike Phillips
Thanks for the info. 3 years is pretty good. I'll keep this kit in mind.
Yes, I watched the entire time and it was a good session. But I know Mike was satisfied with the polishing results, but for me it needed sanding. The sanded side looked so much better that the passenger side (polish only). But I am biased toward sanding anytime I see headlights with that much yellowed plastic.
Thanks to Mike's teaching these techniques in his classes, I have done most with the sanding technique. Once they have started to craze or show the interior cracking, no process will clear that up except buying new units. But you can bring back 'clear eyes' with the methods Mike demo'd in the live class on YouTube.
I wish I could do more of these type of small detail jobs, seeing headlights like those drive me almost do the job in parking lots. AG-store has so many options but the Meguiar's kits are easily the best in terms of price for the DIY'er.
As to long term protection, my dollars are on PPF over that plastic. That way you get protection from rock chips, bug splats, and UV to last until you replace the film. I have used two coatings, Optimum and McKee's, and they will do the job for the short-term. Nothing is perfect and will last but better to do something rather than live with ugly lights.
