What dissolves dried on Ceramic Coating?
Hi all,
Trying to repurpose a blue glass bottle that held ceramic coating, and had dried on the surface of the bottle.
Tried Mineral Spirits - Strike 1.
Tried Acetone - Strike 2.
Can you think of anything that would working cleaning this off, or should I just bite the bullet and find something else that has the specific dropper type I was interested in repurposing?
Any feedback appreciated...tried to find MSDS on specific product that hardened, with no luck.
TIA...Eric
Re: What dissolves dried on Ceramic Coating?
Does the blue bottle hold some sentimental value, Eric? Lol
Just kidding. :)
But, I'm not sure what would "dissolve" a ceramic coating that would not be extremely caustic.
Polishing (abrading) it off is the only thing I would think would work. But........... JMO.
Quote:
Originally Posted by
PaulMys
Just kidding. :)
What Paul said. The only way to take it off safely is by wet-sanding and/or compounding with an aggressive pad and compound.
PaulMys
Eric
How long have you been on the forum brother? Seems like you know many other members by their first name. Is there a directory some where where I can get to know others first names as well? Thanks for any help you can provide Paul!
Jacob Harrod AUTOCLEAN
The OP posted his name in the 1st post
Lol...I always post my name, but Paul probably does know a lot of folks "personally".
Yes...it does hold sentimental value, and I guess I should be glad that nothing is taking it off, since I would want that behavior on my car.
I'll bite the bullet; try to find new one via the web.
Thanks for the replies, kind of knew I was screwed as soon as I emptied the bottle of mineral spirits after letting it soak overnight.
E
Coatingsarecrack
And if you view the forum on a web browser you can see the members "join date". I don't think you see that if you're using a mobile app, which is a bummer because things like location and how long they've been around might be useful in a conversation.
Back on topic: I couldn't imagine a product any person could easily buy dissolving a coating. Those left over solids are essentially a form of quartz which is the foundation of sand or glass.
ejaf
E
Disclaimer:
Whatever that is suggested below is solely
intended for the removal/dissolving of the
Coating residues from the OP’s “blue bottle”.
Nothing more; nothing less.
•Unless the Coating was one of Optimum’s
SiC resin-based Coatings...then high pH
products (such as alkaline degreasers)
can do wonders in removing/dissolving the
majority of SiO2/TiO2 resin-based Coatings.
-Note:
It may take the blue bottle
soaking for awhile, or two,
to totally remove
the Coating residue.
•But if/when in doubt, I suggest contacting
the manufacturer of the Coating.
-IMO: in the long run...it’s in their best interest to
assist you in your quest to remove their Coating.
-(You may want to re-apply it to your vehicle
when the original application wears thin.)
FUNX650
Disclaimer:
-Note:
to totally remove
Thanks, Bob!
E
If solvents are found that work easily to wipe over and remove coatings - and - without also harming car paint - that would be a minor strike against one of the main benefits of paint coatings
Longevity
Just throwing that out there for discussion.
