Dr. Beasley's Z1 - Bass Pro Shops Nitro Z19 Bass Boat - Ceramic Coating Gelcoat
Gelcoat is polyester resin with different types of pigments added to create color. Bass boats have historically been made out of gelcoat with the addition of LOTS of METALLIC FLAKE added to the gelcoat to give them a very flashy and wild look.
This Nitro Z19 Bass Boat is no exception to the history of this style of building a bass boat. My brother-in-law recently purchased this Nitro Z19 new from a local Bass Pro Shop here in Florida. It's a 2018 model that never sold but over the 3 years has seen enough wear-n-tear on display and also test drives and then fishing trips via PJ, my brother-in-law that it has a swirled-out gelcoat finish.
No Wax Protection
This boat to our collective knowledge has never been waxed or sealed in any way, at least not professionally. My brother-in-law fully understands the benefits of a ceramic coating. He knows besides lasting longer than a wax or sealant, the ceramic coating makes clean-up faster and easier. This is a fresh water boat but the water you might picture when you read the words "fresh water" is not the clear blue bubbling water you imagine in a mountain stream. Far from it. It's a brownish, murky water that is normal to fresh water lakes in Florida. So PJ traded me the use of his boat for a number of projects and in return, I would install a ceramic coating to the boat and the trailer.
Anyway, PJ told me he wanted to get his boat ceramic coated so after a day of fishing, he could simply pull through any Coin-Op Car wash and BLAST the boat and trailer to knock off any Lake Water Scum before storing the boat.
Fast and Easy
So this last Saturday, I coated the boat. I wanted to do a GREAT job for my brother-in-law because he's such a cool dude and has been such great friend to Autogeek over the years BUT I also wanted to make the job (work), as fast and easy as possible. While there's not a ton of real-estate like you would find with a Center Console boat like this one we coated recently, it is a somewhat complicated design to machine correct. The trailer fenders are also gelcoat and very curvy. Then there's the motor and also the front of the console as well as the driver's side of the console with all of it's gauges, switches and buttons.
8 hours
It took me roughly 8 hours to machine correct and then coat this boat working non-stop. And this was the fast and easy approach. :D
Dr. Beasley's Z1
Recently Jim Lafeber aka Dr. Beasley, released a brand new product he's been working on. I've used it on a few cars with great success. This is basically what I would call a,
Ceramic AIO
That is, it's a one-step cleaner/wax or AIO only instead of using "wax" or some type of "sealant" for the protection aspect of the product it uses a unique nano-structure resin/coating formulated using TiO2, (Titanium Dioxide), and SiO2 (Silicone Dioxide).
Besides using the TiO2 and the SiO2 for protection, Jim also says,
A: You don't need to chemically strip the paint after using the product in you want to apply a dedicated coating over the top of it.
B: You can use your favorite brand of coating over it - you don't have to use a Dr. Beasley's brand of coating over it.
And of course, you don't have to top it at all if you don't want to. The Z1 is a stand-alone product. This means one and done.
I don't think there's anywhere on the label of Z1 or anywhere else where it states the product can be used on gelcoat. There's nothing that says it cannot be used on gelcoat. So throwing caution to the wind, I chose to use Z1 for the correction step, which would also leave everything buffed with it sealed and protected with the TiO2, (Titanium Dioxide), and SiO2 (Silicone Dioxide), nano-structure coating. And because you can apply or top this foundation with any other coating, I also applied a second, dedicated coating after all the gelcoat correction work.
Here's the 2018 Nitro Z19 as it arrived to Autogeek's Show Car Garage.
http://www.autogeekonline.net/galler.../Nitro_020.JPG
Metallic finishes hard to photograph
Metallic paint is more difficult to photograph than non-metallic paint. LARGE metallic flake gelcoat is also more difficult to photograph than non-metallic gel-coat. Regardless, in the pictures below I did my best to photo-document the before condition and the results from my Test Spots.
Hard or soft?
I assumed the gelcoat would be hard. That's what everyone always says about gelcoat - it's hard. Harder than paint. I think this is generally true when it comes to pigmented gel-coat, but this is clear gelcoat resin OVER the metallic flake pigmented resin. There's a difference. When working on pigmented gelcoat or polyester resin, you're working on both the resin and the pigment at the same time. Some pigments are hard and some or soft - but either way, the pigment alters the hardness or softness of the resin.
When working on straight resin - it is what it is. It's hard or soft or somewhere in-between. It's just clear resin, NOT affected by pigment. I can only go by what I found out using Z1 with two different RUPES CP foam pads. But my initial impression is - this gelcoat on this boat is not that hard. I easily corrected it using the yellow CP foam pad with Z1 and this is not an overly aggressive combination by anyone's standards.
Tape-line
When doing a Test Spot you do NOT have to use a tape line. I do this to better get and then share for decades the before and after results using a strong demarcation line. I think this helps to tell the story and because I never know the knowledge level of the hundreds and thousands of people that will read my work into the future I like to fool-proof it.
http://www.autogeekonline.net/galler.../Nitro_021.JPG
Swirl Finder Light
In order to photograph the before and after results and in order to see for yourself - you need a great hand-held light.
http://www.autogeekonline.net/galler.../Nitro_022.JPG
Before & After on both sides of the Tape Line
http://www.autogeekonline.net/galler.../Nitro_023.JPG
http://www.autogeekonline.net/galler.../Nitro_024.JPG
http://www.autogeekonline.net/galler.../Nitro_025.JPG
http://www.autogeekonline.net/galler.../Nitro_026.JPG
http://www.autogeekonline.net/galler.../Nitro_027.JPG
http://www.autogeekonline.net/galler.../Nitro_028.JPG
http://www.autogeekonline.net/galler.../Nitro_029.JPG
http://www.autogeekonline.net/galler.../Nitro_030.JPG
http://www.autogeekonline.net/galler.../Nitro_031.JPG
http://www.autogeekonline.net/galler.../Nitro_032.JPG
http://www.autogeekonline.net/galler.../Nitro_033.JPG
FLEX Supa BEAST
I love this tool. It is a 8mm gear-driver orbital that is lightweight, quiet, smooth and cool-running. In my opinion, tools like this are the fastest way to do correction work as fast as humanly possible while keeping while producing professional results. This tool has a part number but I don't know what it is and don't care to remember or type it out each time I reference it.
http://www.autogeekonline.net/galler.../Nitro_035.JPG
RUPES CP Foam Pads
CP stands for Contour Profile. I don't believe RUPES officially calls their new pad line, "CP Foam Pads" but I do and I type more about their pads than anyone in our industry and probably more than anyone at RUPES - so the name is now established. The new RUPES pads are now referred to as RUPES CP Foam Pads. You can read more about them here.
For my first Test Spot I'll be using the yellow CP polishing pad. This is a great all-around foam polishing pad for all kinds of work. It also fits and runs super on the Supa BEAST.
http://www.autogeekonline.net/galler.../Nitro_036.JPG
Dr. B's Z1
http://www.autogeekonline.net/galler.../Nitro_037.JPG
Priming the pad
I don't normally prime foam pads any more. Quit doing this a number of years ago. Mostly because I'm lazy but also because after you make a few section passes using foam pads with just applying a circle of product or some drops of products, the action of an orbital will enable the product to migrate around the pad and SELF-PRIME the pad.
One reason I'm priming the pad is because the Z1 has a somewhat chunky toothpaste consistency that does not soak in or even grip the face of a foam pad. So if you put some drops of product or a circle of product on the face of the pad and then turn the pad over to place on the surface to be buffed - if you're not fast - the product will via gravity fall off the pad. By priming the pad 100% of the surface is going to go to work for me with or without product migration.
http://www.autogeekonline.net/galler.../Nitro_038.JPG
After the pad is primed - then I will add some product to work with...
http://www.autogeekonline.net/galler.../Nitro_039.JPG
Working Product
Anyone that's ever read any of my how-to books, how-to articles or video work knows I call the product on the pad my, Working product. It's the product I'm going to be working. When you create as much written content as I do you must have words and terms for the things you talk about or type about. :D
http://www.autogeekonline.net/galler.../Nitro_040.JPG
Film of Z1
I just took these pictures so you could see what a film of Z1 looks like on the surface after doing a number of standard protocol section passes.
http://www.autogeekonline.net/galler.../Nitro_041.JPG
http://www.autogeekonline.net/galler.../Nitro_042.JPG
Wipe-off
I show these rather inexpensive edgeless flat weave towels a lot - for a reason.
http://www.autogeekonline.net/galler.../Nitro_043.JPG
Impressed
Here are the results and I will say considering I'm only using a foam POLISHING PAD - I am impressed with the defect removal and the restored CLARITY to the polyester resin.
http://www.autogeekonline.net/galler.../Nitro_044.JPG
http://www.autogeekonline.net/galler.../Nitro_045.JPG
Test Spot Number #2
While the results from the foam polishing pad were great I wanted to see how much more defect removal I could get out of the Z1 by testing the blue RUPES CP foam pad.
http://www.autogeekonline.net/galler.../Nitro_046.JPG
Before and After
http://www.autogeekonline.net/galler.../Nitro_049.JPG
http://www.autogeekonline.net/galler.../Nitro_048.JPG
http://www.autogeekonline.net/galler.../Nitro_047.JPG
http://www.autogeekonline.net/galler.../Nitro_050.JPG
http://www.autogeekonline.net/galler.../Nitro_051.JPG
My thoughts?
While I did see damn near perfect results, thus more, better and even faster correction using the blue foam cutting pad over the yellow foam polishing pad, I chose to do the entire boat using the yellow foam pad.
Why?
Because it's a fishing boat - not a show boat. The yellow foam pad buffs nicer because it's softer and it did more than enough correction work for what this boat is in context - a fishing boat. A fishing boat that's going to see a LOT of fishing and thus in all likelihood see more swirls and scratches into the future. While my goal IS to make it look nicer, the primary goal is to machine correct the gelcoat finish to get it CLEAN as in nothing else on it while leaving it protected. Plus prep it for the secondary dedicated coating installation.
Process
After testing two different pads I dialed-in my process. I used the Supa BEAST with the Z1 and the RUPES Yellow CP Foam Polishing pad for the majority of the boat. For some sanding marks I found in the trailer I used the blue foam cutting pad with the Z1 to remove these and for the motor I used a RUPES White CP Foam Finishing pad.
http://www.autogeekonline.net/galler.../Nitro_052.JPG
Re: Dr. Beasley's Z1 - Bass Pro Shops Nitro Z19 Bass Boat - Ceramic Coating Gelcoat
Continued....
Sanding marks
I found two areas with repairs and sanding marks left behind by the technician - hack? Whatever you want to call them.
Looks fine without a great hand-held light?
http://www.autogeekonline.net/galler.../Nitro_053.JPG
Now look...
http://www.autogeekonline.net/galler.../Nitro_054.JPG
Those are DA Sanding Marks
I removed them with the Z1, the Blue RUPES CP Foam Cutting pad and the pure brute strength of the Supa BEAST!
http://www.autogeekonline.net/galler.../Nitro_055.JPG
Here's what I used...
http://www.autogeekonline.net/galler.../Nitro_056.JPG
http://www.autogeekonline.net/galler.../Nitro_057.JPG
http://www.autogeekonline.net/galler.../Nitro_058.JPG
Used one full Tube and about 2/3rds of a second tube
http://www.autogeekonline.net/galler.../Nitro_059.JPG
http://www.autogeekonline.net/galler.../Nitro_060.JPG
http://www.autogeekonline.net/galler.../Nitro_061.JPG
http://www.autogeekonline.net/galler.../Nitro_062.JPG
http://www.autogeekonline.net/galler.../Nitro_063.JPG
http://www.autogeekonline.net/galler.../Nitro_064.JPG
http://www.autogeekonline.net/galler.../Nitro_065.JPG
http://www.autogeekonline.net/galler.../Nitro_066.JPG
http://www.autogeekonline.net/galler.../Nitro_067.JPG
I removed the cool looking cowl and machine corrected both sides plus the gelcoat behind it.
http://www.autogeekonline.net/galler.../Nitro_068.JPG
http://www.autogeekonline.net/galler.../Nitro_069.JPG
http://www.autogeekonline.net/galler.../Nitro_070.JPG
http://www.autogeekonline.net/galler.../Nitro_071.JPG
http://www.autogeekonline.net/galler.../Nitro_072.JPG
http://www.autogeekonline.net/galler.../Nitro_073.JPG
http://www.autogeekonline.net/galler.../Nitro_074.JPG
http://www.autogeekonline.net/galler.../Nitro_075.JPG
http://www.autogeekonline.net/galler.../Nitro_076.JPG
I followed PJ home and took a couple of parting shots.
http://www.autogeekonline.net/galler.../Nitro_077.JPG
http://www.autogeekonline.net/galler.../Nitro_078.JPG
She's ready to go back in the water!
http://www.autogeekonline.net/galler.../Nitro_079.JPG
Review
I found the Z1 to more than compatible with pure polyester resin. This boat corrected easy and the results were "show car results" on a boat. The Z1 corrected and SEALED the gelcoat in one step. The finish it left behind was smooth, glossy and slick. The boat looked freaking amazing when I we were done. The Z1 wiped off easy on this boat. One thing I did though was only buff small sections at a time and then immediately wipe off the residue.
In my opinion, an Ceramic AIO is a great way to go for a boat. You get correction and protection in one step and down the road you - if you have more swirls and scratches you simply whip out your polisher and tackle the sections that need correction repair.
One and done and longer lasting protection than a wax or sealant. Cool new product from the Doctor.
Everything I used can be found on Autogeek.com
Continued....
In my rush to get through this project I forgot to take some after pictures where the sanding marks were but I did take a video and share it to my FB page.
Sanding marks before
DA sanding marks
Sanding marks are gone!
Sanding marks gone!
More...
Besides the gelcoat correction work we also used,
303 Products
SONAX Polymer Net Shield
I'll share these product and where we used them tomorrow.
Awesome.....
Will let my customer know that we will indeed coat his boat this fall!
Thanks for the write up.
Tom
Quote:
Originally Posted by
TMQ
Awesome.....
I see this product as a good fit for boats in good to excellent condition or for doing regular maintenance.
And of course, good for brand new boats. From experience, most new boats have holograms. The boat building business is more on the Caveman side versus staffed with trained people that know what we know.
As for they types of boats I bring into my boat detailing classes - these will still need to be machine sanded followed by heavy compounding.
A Ceramic AIO could be used to polish severely neglected and oxidized boats AFTER the sanding and rotary wool pad step.
