5 Attachment(s)
Worst Case scenario for Brake Dust! Need Advice
Hey everyone, joined about a week ago and this is my first post. I am really thankful if someone could educate more than what I could search on the internet.
I have a 2003 Toyota Sequoia as my daily driver and the rims are stained bad with brake dust, rust and flaking.
I am new to car repair and detailing so I would really appreciate some guidance and help on this.
All I know is that I have to wax the rims after a good cleaning to seal the finish (not sure if my rims may need an extra step). At worst, I understand if I need to get new rims entirely but wanna see what I can do before that.
Firstly, what type of cleaner should I use because of the flaking: Aluminum coated or non-aluminum coated?
Attachment 71168Attachment 71169Attachment 71170Attachment 71171Attachment 71172
Re: Worst Case scenario for Brake Dust! Need Advice
Welcome to forum. Ill leave the recommendations for someone else but man what a great before and after this is going to be. Don't rush, get all the supplies and take pictures galore.[emoji1417][emoji1417]
Sent from my SM-N986U using Tapatalk
I haven't had to use something as powerful as Mequiars wheel brightener but this looks like a GREAT candidate [emoji362] Once you clean them really good, get yourself some 303 Touchless Sealant to spray on them after you've rinsed them. After the wheel has been cleaned really good and the wheel is still wet you simply spray some on the rim, enough for coverage, wait about 20-30 seconds and rinse off. You'll be amazed at the water beading and the next time you wash the truck and get to cleaning the rims, it will be that much easier, well, as long as they don't get THAT bad again. Finally a great wheel cleaner for maintence cleaning is called Brake Buster and the preferred method for use is through a foaming sprayer and works great at 4:1.
Welcome to cult... urrrr, forum [emoji1]
Quote:
Originally Posted by
Klasse Act
Meg's WB might be to strong for those pitted wheels. If the acid gets under the clear and paint, it may start to delaminate. Iron X might be a safer cleaner.
Rsurfer
Great point, didn't realize how strong the acid was in there[emoji50]
OP, your going to want to get yourself a couple good wheel brushes as well. The Speed Master and Mother's wheel brush are 2 good ones to start with[emoji362]
Btw that Brake Buster also works on your tires as well[emoji106][emoji106]
Thanks for the advice and Im gonna make sure to get a good picture each step of the way.
Question: If the Mequiars Wheel Brightner for whatever reason does not work, should I retry with the same product or different product before even attempting to put on the sealant?
I would think that I trying to perform another cleaning over the sealant would be difficult, please correct me if I am wrong?
Meg's WB is a strong chemical, so wear protective gear. If you are going to use MWB try diluting it first. You can always increase the ratio as needed.
You won't find anything stronger for wheels OTC than Meg's Wheel Brightner.
Clean them to the best of your ability before applying the sealant and something like 303 Touchless Sealant is one of the best easiest to use and the bottle will last you quite a while.
If you have rust and flaking of the finish, those wheels need to be refinished first, then you worry about a cleaner to handle the brake dust. I like Wolfgang Uber Wheel Cleaner for very dirty wheels, if just lightly dirty, I use Brake Buster.
Wax won’t do anything to protect wheels, at least not more than a few days. If you get the wheels refinished you’ll want to ceramic coat them. Then you have a year or more of protection.
BSoares
I agree after reading these comments and it leads me to something I'm very good at...spending OTHER people's money[emoji383][emoji383][emoji383] May I suggest a set of the 1552 rims that are for trucks that look off road cool as hell[emoji848][emoji106][emoji362]
