Re: Griot's Complete Polish
I’ve used it as well as Complete Compound. It does what it says. Removes light swirls and polishes the paint.
Perhaps use it with a black griots finishing pad with two or three section passes and it’ll shine things up nicely.
Works great with an light cutting pad or polishing pad on a DA.
Just about any polish sold here on AGO has great abrasive technology.
Griot's is no exception.
The thing is, you have to do testing with different pads, products, machine(s), and your own techniques to find out what works best for you and your paint.
There is no one product (polish in your case) that is the "magic bullet" for every case.
Thank you all very much for the info and advice. I have polished many cars in past, but used Menzerna SIP followed up by a finer Menzerna product whose name escapes me now. Good to know the Griot's complete polish will do the job on fine scratches.
Quote:
Originally Posted by
The Guz
That's a great write up. Thanks for the link.
I think Complete Polish and Complete Compound came out a while back to replace their old Machine Polish 1-4 system. Given that timeline, they were made to be used with the 8mm GG6 or by hand.
When the BOSS creams came out, those were designed with a long throw in mind. From looking through the Q&A section on their website, I swear I remember seeing that it's only the 15/21mm machines where they don't recommend the Complete Compound/Polish.
I've used the Complete Compound, and it was a dream compared to the old Machine Polishes. I've been using the BOSS creams since then, but I don't remember the Complete Compound being a Sub-Par experience in comparison.
Hope this helps.
oneheadlite
Hope this helps.
Yes I have a flex and a 5yr or so old Griots da polisher. I plan to use with the Griot's polisher and limit the passes to probably 3.
Why do you say limit the number of passes to 3? If you're doing such a short cycle you may need to use polishes with SMAT and not DAT because with just 3 passes the diminishing abrasives probably won't even break down to their finishing state.
I've only used the Boss creams and I know those are SMAT, not sure about the Complete Polish.
