Can this exterior trim be restored?
I think it’s likely from being parked outside and exposed tot he elements... without regular washes. Is there a product that can restore its appearance? What can I try?https://cimg7.ibsrv.net/gimg/www.clu...7e1dfc7b82.jpg
Re: Can this exterior trim be restored?
I'm impressed with Cerakote Trim Coat so far on two cars I've used it on.
Thanks, I'll do some research on those.
You could try Solution Finish as well
The trim looks a lot like a rubber compound.
If it is, use a dedicated rubber cleaner to purge all of the embedded contaminants and follow up with a rubber or trim restorer.
After using a restorer, you can apply a ceramic coating to ensure it won’t happen again.
Quote:
Originally Posted by
WristyManchego
Came here to post this. Agree.
Sent from my SM-G988U using Tapatalk
