LIVE Detailing Class: Will this buff out?
How deep is too deep?
https://youtu.be/3CZgE28gjoE
We have the perfect demo car. This is a co-workers car and it has the all too familiar scratches in the trunk lid that look like someone set something on the trunk lid and then dragged it off.
What do you think? Too deep to buff out?
http://www.autogeekonline.net/galler.../Malibu_03.jpg
These scratches are on the top of the trunk lid on this Malibu
http://www.autogeekonline.net/galler.../Malibu_02.jpg
http://www.autogeekonline.net/galler.../Malibu_01.jpg
Re: LIVE Detailing Class: Will this buff out?
I'm looking forward to it. I have been looking at Defelsko paint mil gauges. We use them daily at work, but not sure it's something I need immediately, or after I do more details.
More...
This topic, how far to buff? Comes up often enough that recently I wrote an article on it.
When to stop buffing - Or - How far should you go to remove swirls and scratches?
And yes more.....
We will also be going over the best practice of doing a Test Spot.
The two reasons WHY you should always do a Test Spot before buffing out any car
The value of a Test Spot
Years ago, I started using the term Test Spot on the Internet, back when the first car detailing discussion forum was created. I'm sure I'm not the first guy to figure out to "test" a process to one small area before buffing out an entire car but I can document I am the first guy to coin the term and make it popular via the Internet.
No big deal, I just tend to share what I call, car detailing history in all it's forms on this forum and other social media platforms including my classes. Some people find it fun and interesting how we got to where we are today from when car detailing started with the invention of the car. I also cover this in my how-to book, The Complete Guide to a Show Car Shine.
Here's the thing about a Test Spot. You're NEVER so good at paint correction that you don't need to do one. Never. I always do a Test Spot to any car I've never worked on before. Always. The only time I might skip a Test Spot is if I've already worked on the car previously and in most cases I'm going to use the same products, pads and tools. Thus nothing has changed.
What the Test Spot shows you
I'm typing this out and may turn this into a dedicated article because I often see people recommend to others to do a Test Spot and I see people talk about Test Spots, but I rarely see anyone explain the two reasons as to WHY to do a test spot. So I'm going to share that here.
1: To dial in a process that gets the job done to your expectations
A Test Spot will show you whether your choice of product, pad, tool and technique will remove the defects to your satisfaction while leaving behind a finish that meets your requirements and satisfaction. Now the quality of results can be different for different cars and different people.
For example,
Production Detailing or Daily Driver Detailing
If you're doing production detailing, using a one-step cleaner/wax also called an AIO or All-in-One, you probably are not trying to remove 100% of the swirls and scratches so you won't be as picky about the results from your Test Spot as someone doing show car work.
High-end Paint Correction or Show Car Detailing
If you're going to prep a car for display at a car show like SEMA or TV, or you're installing the latest 11h hardness Ceramic Paint Coating and the package you sell including removing all the removable paint defects, then your Test Spot will show you if you are in fact removing 99.9% of the defects - or not.
So a Test Spot is used to show you if your choice of product, pad, tool and technique are removing the defects to your satisfaction level and expectations. If it's not, then before you buff out the entire car you do a second Test Spot only for this second Test Spot you alter something in the process. For example if you're not removing enough of the removable defects you could switch to a more aggressive product, or more aggressive pad or a more powerful tool and possibly change all 3 of these things. You could also modify your technique, for example shrink the size of your work area down, that is buff a smaller section of paint or make more section passes over the paint. The BIG PICTURE is to find a way to remove more paint faster to more efficiently level the surface - without of course, buffing through the paint.
The above is the first half of the answer as to WHY to do a Test Spot.
2: To figure out the least aggressive approach
The second half of the answer, and this is the part that most people either don't know or understand or they simply cannot explain it or verbalize it and that is,
Use the least aggressive approach to get the job done
The words get the job done means what I explained above, that is remove the defects to your expectations and satisfaction. The part about using the least aggressive product, this is the part the people can't or don't explain. I'm sure they understand why at some level it's just not everyone is good at speaking what they mean or in the case of a forum, Facebook, comments on YouTube, when talking in person, they don't include the actual heart of the matter as to why to test and when testing, using the least aggressive process to get the job done.
Here's why,
To leave the most paint on the car
Simple huh? Sure it's simple but I've been in this industry all my life now and I NEVER hear some say or explain this portion of the reason to do a Test Spot or use the least aggressive process to get the job done and I also never see anyone type it anywhere.
So in case you didn't know, the reason you do a Test Spot is to dial in a process that removes the defects to your satisfaction while leaving the most paint on the car..
Paint is thin, especially factory paint. A custom paint job will tend to be thicker. Even so, no matter what type of car you're working on, production car with factory paint or a custom car with a custom paint job, as a professional you still approach the paint correction process the same way, you do a Test Spot and dial-in a process that removes the defects to your satisfaction level or expectations while leaving the most paint on the car.
That's the two reasons why you should ALWAYS do a Test Spot to a car before buffing it out.
:bump:
Here's a video I just shot to show the topics we'll cover today.
http://www.autogeekonline.net/galler...w-Deep_011.JPG
Check it out.... we go live in about 35 minutes as I type...
:updated:
Just added the YouTube video to the first post in this thread.
Yancy is awesome! Lol
Another GREAT video, boys. :)
Very good topic and the perfect car as example. I could see that Mike was relaxed after his vacation time, came back with smiles and lots of banter with Yancy. Suggested video and good tips on the Defelsko paint thickness gauge.
