Re: Rust repair and touch up
Great solid advice, thank you for taking your time to help and help each other.
Thanks Mr. Mike for your awesome advice here about removing rusting and touch up :applause:
Looks good.
I wish my 14 Explorer only had a couple rust spots.
The tailgate on it is actually rusting from inside out. Multiple rust bubbles under the paint across the bottom.
The only real way to correct it is to cut out the bad metal, weld in new and then paint. I'm nowhere near that ambitious.
I might try to sand off as much rust as possible and try some rust converter to at least slow it down.
Then hit it with some rattle can paint/2k clear. Might be able to blend it a bit below the bottom crease (about 3" up from bottom) so it's not obviously a different color.
Looks pretty good to me.:xyxthumbs:
