1 Attachment(s)
Cleaning dusty motorcycle before ride
So I have a black motorcycle (1993 Triumph Trident 900). It sits under a tent of sorts by the side of the house (New Jersey). If I let the bike sit for a day, it’ll be covered in dust, specks of dirt and leaves that swirls around as the tent isn’t completely sealed. I used to use the California duster but that has wrecked the paint with swirl marks. When I need to ride, I can’t always do a complete wash as it’s not practical. I can’t ride the bike dirty either because my jacket and my thighs run the dust and particles into the tank causing scratches.
Now, I’m looking into paint correction and trying to figure out how to avoid this situation in the future. I have been using Griots Garage Spray on Car Wash, wiping it off with one towel and then buffing it off with another towel. I think it’s working. Can this type of method work safely? Is there another idea that you guys can give me?
Attachment 69636
Re: Cleaning dusty motorcycle before ride
I really like that tool, but I don’t have an air compressor. I do, however, have a blower that I have been using to blow much of the dust off. It’s the Cyclone Blower and it is filtered. It helps but not completely. I then use the Griots rinseless spray. Afterwards, I would apply some Griots quick detail and buff off. Do you think that would be enough lubrication to prevent swirls and scratches? Is there another that is more viscous or more lubricating that would work?
1. Blow off what dust you can
2. Use the Griots Garage Spray on Car Wash but make sure you are using your MF towel(s) correctly. Check out this article from Mike P. :
How to correctly fold and use a Microfiber Towel
By using this method you will have 8 fresh "sides" for each towel. Make one wipe per "side" thus ensuring you aren't wiping previously-removed dirt back in to your paint and causing scratches, etc.
3. Consider trying something like Wolfgang Uber Rinseless Wash or Optimum ONR. These concentrates will allow you to make your own spray = more cost effective + you can alter the mix ratios to increase lubricity (ie. using the waterless wash ratio or quick detail ratio).
Probably your safest method would be to use one of these concentrates, mix up a rinseless solution in a bucket (go slightly stronger if you're really worried), soak multiple MF towels in the solution for a few minutes, and then wash with the MF towels (still use the 8 "sides" method).
Quote:
Originally Posted by
57Rambler
This is exactly what I was looking for. The folding microfiber trick is brilliant. That way, the dirt doesn’t see the paint again. I have Opti Coat No Rinse and Opti Coat Hyper Seal. I could make a spray using that as a washing method at the washing concentrate. Thank you so much.
SJTrance
You're welcome.
But really the kudos should go to Mike P., he seems to know a thing or two about this detailing stuff. :laughing:
