Help! Cleaning Brake Fluid stain off ABS plastic BMW Fairing
Looking for advice for removing a stain from ABS plastic - DOT 4 brake fluid leaked and stained a bright yellow BMW Motorcycle Fairing.
The fairing is made of a high grade ABS plastic, the color is not paint it appears to run through the material. I've tried removing with cleansers with no success. Polishing with a fine abrasive helped but did not completely remove the stain. The fairing plastic did not bubble - but you can still see the stain drip marks beneath the master front brake cylinder.
Any Ideas?
Re: Help! Cleaning Brake Fluid stain off ABS plastic BMW Fairing
Can you post up some pics please? In my experience chemical stains, specifically on plastic/plastic type materials, unfortunately are usually permanent.
2 Attachment(s)
Attachment 68843It is difficult to see the stain with my cheap cell phone camera sorry.
But there are several drip mark stains beneath the master cylinder (mounted on the handlebar) -
immediately above and to the left of the round BMW insignia, as you are looking at these pictures Attachment 68844
