Pictures: 24' Pro-Line Center Console - Detailing Class - 2013
From August, 2013
We used Steve's boat for some new segments on Ship Shape TV and tonight we're going to finish the boat and then install new graphics.
Here's a few pictures from today's filming for Ship Shape TV. I'll start an actual "Pictures & Comments" thread for the full write-up plus all the before and after pictures. (This is just the sign-up thread)
Most people would look at this boat and think the black gel-coat is in pretty good shape?
http://www.marine31online.com/galler..._Class_010.jpg
Here's what it really looks like, you just need some light...
http://www.marine31online.com/galler..._Class_011.jpg
http://www.marine31online.com/galler..._Class_012.jpg
And here's some pictures from last night's project. Note that Steve and I washed the boat during the day using the Marine 31 Foam Gun some Marine 31 Wash & Wax with Carnauba
Step 1 - Compounding
First thing was to compound the gel-coat. For some of the guys, compounding oxidized gel-coat using wool pads with rotary buffers was new for them and I think one of the things they had the chance to learn was how to lean into the buffer a little to really do some chopping on the oxidation...
Joseph running a rotary buffer to remove oxidation...
http://www.marine31online.com/galler...Class_027a.jpg
http://www.marine31online.com/galler...Class_028a.jpg
http://www.marine31online.com/galler...Class_029a.jpg
http://www.marine31online.com/galler...Class_030a.jpg
This is how you lean into the buffer....
http://www.marine31online.com/galler...Class_031a.jpg
DeWALT 849X sans handle and grabbing the rubber overmold on the head of the unit and the pushing down hard...
http://www.marine31online.com/galler...Class_032a.jpg
Re: 24' Pro-Line Boat - Extreme Marine Makeover - Oxidation Removal
Continued...
While some of use were compounding the black gel-coat, others were tackling the white gel-coat cap using PFWs or Purple Foamed Wool Pads with our new Gel-Coat Heavy Cut Cleaner/Wax and Flex 3401 Forced Rotation Dual Action Polishers.
The fibers that make up the PFWs are encapsulated with foam and this creates a pad that offers good correction due to the fibers leveraging any abrasive or chemical cleaners while the foam helps to maintain good gloss for finishing.
The forced rotation Flex 3401 provides plenty of power without instilling swirls at the same time.
Joseph using a Flex 3401 with a 4" Backing Plate and a 4" PFW
http://www.marine31online.com/galler..._Class_033.jpg
http://www.marine31online.com/galler..._Class_034.jpg
Chris using a Flex 3401 with the factory 5.5" backing plate and a 6.5" PFW
http://www.marine31online.com/galler..._Class_035.jpg
http://www.marine31online.com/galler..._Class_036.jpg
Shawn using a Flex 3401 with the factory 5.5" backing plate and a 6.5" PFW
http://www.marine31online.com/galler..._Class_037.jpg
Den using a Flex 3401 with a 4" PFW
http://www.marine31online.com/galler..._Class_038.jpg
Continued...
While most of us were working on removing oxidation and/or using a cleaner/wax on the cap, Jay and Steve were using HEAT GUNS to remove the old graphics and the Boot Stripe.
Jay is really good at getting just the right balance of heat and pulling on the old boot stripe without tearing the old, weathered vinyl...
http://www.marine31online.com/galler..._Class_039.jpg
http://www.marine31online.com/galler..._Class_040.jpg
Steve's working on removing the boot stripe on the other side...
http://www.marine31online.com/galler..._Class_041.jpg
http://www.marine31online.com/galler..._Class_042.jpg
Success! The vinyl boot stripe is off the boat and on Jay! Thank you Jay!
You ca also see Paul following Jay and using 3M Adhesive Remover to remove the adhesive residue. Thanks Paul!
http://www.marine31online.com/galler..._Class_043.jpg
http://www.autogeekonline.net/forum/...lies/smile.gif
Continued....
After compounding the black gel-coat we then polished it using the Flex 3401 with foam polishing pads to remove the holograms left by the wool pads. I didn't get any pictures of this process as I was busy running a rotary buffer and after that running a Flex 3401. Just wanted to note that we did machine polish the boat and did NOT go straight to wax after the rotary buffer procedure.
Anytime the last step on your boat is a wool pad with a rotary buffer the results are holograms or rotary buffer trails in the finish.
If you have a white gel-coat boat you might not see them but they are still there. These are simply circular cuts in the surface and they leave the surface more open to deterioration and oxidation than having a completely flat or smooth surface.
Next up we machine waxed the hull...
Here's Jay and Shawn machine applying Marine 31 Gel-Coat Carnauba Wax + Sealant using Porter Cable 7424XP dual action polishers and soft blue foam waxing pads.
http://www.marine31online.com/galler..._Class_044.jpg
http://www.marine31online.com/galler..._Class_045.jpg
http://www.marine31online.com/galler..._Class_046.jpg
Here's Paul and Niki machine waxing the other side.
http://www.marine31online.com/galler..._Class_047.jpg
You just can't beat machine waxing ...
http://www.marine31online.com/galler..._Class_048.jpg
http://www.marine31online.com/galler..._Class_049.jpg
http://www.marine31online.com/galler..._Class_050.jpg
Wipe-off time...
http://www.marine31online.com/galler..._Class_051.jpg
http://www.marine31online.com/galler..._Class_052.jpg
