Originally Posted by
2black1s
Here's how I do chip repairs. This process is very time consuming and thus expensive. It's not for everyone and certainly not for every vehicle. But if you have a special interest vehicle or any super nice vehicle this is the way I'd go...
Paint Chip Touch-Up
I'm an old body shop and paint guy. Don't do it any more but did a lot of custom cars and bikes back in the 1970 – 2000 time frame.
The best process I've found for touching up chips on BC/CC finishes (short of repainting the entire panel) is this...
1) Using the edge of a razor blade or Exacto knife, test the margins of the chip for adhesion and carefully chip/trim away any paint that is not firmly adhered to the substrate.
2) Clean the damaged area using a swap and solvent. Enamel reducer or alcohol is my solvent of choice as it will not damage the existing painted surface.
3) Using a fine tip artist’s brush, dab the chip with the appropriate color. Do not try to make the color coat flush to the existing painted surface - you need room for the clear-coat. Minimize any application of paint outside the margin of the chip being repaired. If you do exceed the margin, clean away the excess as described below in step 6). As with most paint applications, multiple thin coats/layers are preferred over a single heavy coat.
4) Allow the color coat to dry thoroughly. It will shrink a little as it dries and if you did step 3 correctly the touched-up color surface will be lower than the existing paint surface.
5) Carefully clean away any remaining excess color that may have exceeded the margin of the chip. If you're really careful a new and sharp single edge razor blade works well. Very fine (i.e., 1500G) wet-or-dry sandpaper is another option.
6) Again, using your artists brush, apply the clear coat in thin coats until the chip is filled flush or slightly higher than the existing paint surface. As in step 3), minimize exceeding the margins of the chip. Where you do exceed the margins or your paint build is too high, squeegee or slice away the excess using the edge of a credit card, a single edge razor blade, or a swab dampened with an appropriate solvent. Any smeared paint resulting from squeegeeing can also be removed with a swab dampened with an appropriate solvent, or with a light sanding once dried. Slightly exceeding the margins with the final coat is acceptable, and even desirable, as long as it’s a very thin coat. Allow to dry thoroughly between coats and overnight or longer for the final coat.
7) Wet sand the repaired area with 1500G wet-or-dry paper.
8) Polish the repaired area.
It takes some time and patience, but done correctly, this process will yield a virtually undetectable repair on solid colors such as black, white, red, etc. Other colors such as metallics, pearls, etc., are more difficult because it's very difficult to match the lay of the metallic when touching-up with a brush.
All of the materials needed including the paint can be obtained at most automotive paint supply stores and/or many body shops.
Hope this might help some of you in the future.
