Has anyone used the touch up pen that has a reservoir on the top? Is it really that much better than using a fine artist brush?
Printable View
Are you talking about the pen on one end and brush on other?
I could never get the paint to flow out of the pen.
The best I found is a paint code bottle dabbed onto a baggie and the fine artist brush. You can dab and practice on the plastic to acquire the right amount on the bristles.
No clue what you are referring to then. I did some quick searches and couldn't find anything like that.
I am curious once again.
I enjoy working with Dr. ColorChip, so I've never tried the Rock Chip Touch-Up Tool. I've only seen videos of them being used on social media. Looks like a pretty cool tool though.
Are you talking about Loew-Cornell Fine Line Painting Pen? That was brought up by Larry from AMMO a while ago and went viral. I have used it and it does work great. I just hate cleaning it up afterwards as the reservoir and tip are tiny. But it does work well for those tiny rock chips.
If that's not it, then I don't know what you're talking about.
Thanks that's it. The pen I saw came with a fine brush for cleaning. Don't know if it makes cleaning easier. I have a paint chip that I had a PDR guy remove the dent, but the rock removed the base coat.
Because of the size, I was wondering how the pen point would spread out the paint. Does the paint self level within the chip?
It does come with a pick to help clean it but it’s not super easy. But the tool works.
If the chip is more than a tiny dot, you can tap this “pen” in there several times and each time it dispenses a little bit of paint. Sort of levels itself.
Dr Colorchip also works well. And I’ve used that paint with the pen and it was fine. The nice thing about the pen is that it doesn’t lay down a blob. It’s pretty delicate and helps achieve a precise result. Probably works best on horizontal-ish surfaces. Vertical ones can be trickier with any touch up.
