Sun Jow 3001 and a Giimour foamaster. I want to connect them both so I can use the foammaster on the Sun joe wand.
I tried mtm and others but can't find an adapter.
Anyplace to find an adapter?
Thanks
Printable View
Thanks
Just curious, why would you want to do this instead of just buying a foam cannon? I have the SPX3000 and have one that works great with it.
You could find the fittings probably at a Homedepot, Menards, or Lowes to make it work. It would just take some looking around.
This will not work so good for you. As it's 2 different products the Foam Gun and a Foamcannon. The orifice or if it's any in the foam gun it's too big to be used with a PW. So you would get less foam than from the hose if you do couple it together with the PW. Get you a foamcannon and you will be getting a great foam from the foamcannon and PW. Just a friendly advise.
/ Tony
What did you decide to do about finding an adapter?
I have both of these. It will be cheaper and easier to buy an under $20 foam cannon built for a pw
Sent from my SM-G965U using Tapatalk
Went with MATCC foam cannon. Could not find adapters. Yes the Gilmour is a high flow and as eveyone pointed out would probably not work so well.
Thanks
