Review: BLACKFIRE BlackICE Hybrid Liquid Wax
http://www.autogeekonline.net/galler...ce_Liq_040.JPG
What it is?
Liquid, synthetic paint sealant.
What it does?
Protects paint, creates gloss and shine.
When to use it?
On new cars with paint in excellent condition and/or on paint that has been previously washed, clayed and polished. This is a non-cleaning sealant so it should only be used on clean paint.
Why to use it?
Protect your car's finish from the elements and create a beautiful looking finish.
Special Instructions
Apply a thin coat by hand or machine and allow to FULLY DRY before removing.
Key Feature
This product is heat resistant. Over the decades I've seen people worried that a carnauba wax will melt off their cars when the car is exposed to high temperatures. If this describes you or if you live in a geographical area that's sees high temperatures and especially if your car is a daily driver parked outside some of the time, most of the time or ALL of the time, then this is the product for you.
Review and how-to
To be honest, I'm not really good at writing reviews. I think I'm really good at writing something more important and that's how-tos. So if you've been reading any of my writing for the last 17 years online, you've probably seen and maybe even learned a thing or two from some of my how-to articles. So instead of writing just a review, below I'll show you how to use this product and THEN share my review. By using the product on a actual car, I am able to provide HONEST feedback on the product versus what I see too much of today and that's mock-up info.
Step 1: Clean car
You can clean your car a number of ways, for this SIV I'm going to use a waterless wash. The car didn't look dirty when it arrived but at the same time, I don't want to clay a car that has even light dust and this could put scratches into the paint.
Pro Tip
You need lots of clean towels to use a waterless wash. The idea being to switch to a clean towel often so you don't merely remove dirt from one panel and then rub it over the next panel.
http://www.autogeekonline.net/galler...ce_Liq_001.JPG
http://www.autogeekonline.net/galler...ce_Liq_002.JPG
I counted and even for a clean car, I used 7 towels to remove the waterless wash. If you want to know more about how to use a waterless wash, say so in the comments below and I'll link to a video.
http://www.autogeekonline.net/galler...ce_Liq_003.JPG
Step 2: Remove any above surface bonded contaminants
This mean, inspect the paint using the baggie test, if it feels rough to the touch, then using detailing clay to remove the offending contaminants.
http://www.autogeekonline.net/galler...ce_Liq_004.JPG
Knead the clay into a patty about 5" across.
http://www.autogeekonline.net/galler...ce_Liq_005.JPG
Lay down a liberal amount of clay lube.
http://www.autogeekonline.net/galler...ce_Liq_006.JPG
Rub the clay over the paint.
Pro Tip
Place your hand over the clay patty so your fingertips lay PAST the edge of the clay patty.
http://www.autogeekonline.net/galler...ce_Liq_007.JPG
I don't see any contaminants coming off the paint and onto the clay but this could mean the roughness I felt was CLEAR OVERSPRAY PAINT - as this car has been repainted with a custom paint job.
http://www.autogeekonline.net/galler...ce_Liq_008.JPG
Before the clay residue dries, remove it with a clean microfiber towel.
http://www.autogeekonline.net/galler...ce_Liq_009.JPG
The paint already looks more glossy after just a waterless wash and claying the paint. The owner says he's owned the car for one year and since buying it has NEVER waxed it. So it's time to seal this paint.
http://www.autogeekonline.net/galler...ce_Liq_010.JPG
Step 3: Apply the BLACKFIRE BlackICE Hybrid Liquid Wax
You can do this by hand or machine. My running joke here at Autogeek for the last 10 years goes like this,
We don't sell hands - so I show you how to work by machine :)
I'll machine apply to the flat easy to buff panels and hand apply to the smaller and more intricate panels.
http://www.autogeekonline.net/galler...ce_Liq_011.JPG
For the machine application, I'll use the Griot's G9 - 9mm random orbital polisher with a Griot's 6.5" red foam waxing pad on speed 2.
http://www.autogeekonline.net/galler...ce_Liq_012.JPG
Apply some of the BlackIce Hybrid Liquid Wax directly to the face of the pad.
http://www.autogeekonline.net/galler...ce_Liq_013.JPG
http://www.autogeekonline.net/galler...ce_Liq_014.JPG
Then using a slow speed, spread the wax over each body panel using overlapping passes. The goal is to lay down a THIN UNIFORM layer.
http://www.autogeekonline.net/galler...ce_Liq_015.JPG
http://www.autogeekonline.net/galler...ce_Liq_016.JPG
http://www.autogeekonline.net/galler...ce_Liq_017.JPG
http://www.autogeekonline.net/galler...ce_Liq_018.JPG
http://www.autogeekonline.net/galler...ce_Liq_019.JPG
http://www.autogeekonline.net/galler...ce_Liq_020.JPG
For the thin panels and more intricate areas I'll apply a thin coat by hand.
http://www.autogeekonline.net/galler...ce_Liq_027.JPG
http://www.autogeekonline.net/galler...ce_Liq_021.JPG
http://www.autogeekonline.net/galler...ce_Liq_022.JPG
http://www.autogeekonline.net/galler...ce_Liq_023.JPG
http://www.autogeekonline.net/galler...ce_Liq_024.JPG
http://www.autogeekonline.net/galler...ce_Liq_025.JPG
I machine applied wax to the driver's side and I'll hand apply to the passenger side.
http://www.autogeekonline.net/galler...ce_Liq_026.JPG
Both approaches work great with this liquid hybrid wax.
http://www.autogeekonline.net/galler...ce_Liq_028.JPG
IMPORTANT
Allow the wax to fully dry to a haze before wiping off. Not only will this make wipe-off easier, it enables the protection ingredients to make a proper bond to the paint.
http://www.autogeekonline.net/galler...ce_Liq_029.JPG
http://www.autogeekonline.net/galler...ce_Liq_030.JPG
Step 4: After the hybrid wax has fully dried, remove using a clean, soft microfiber towel.
http://www.autogeekonline.net/galler...e_Liq_030a.JPG
http://www.autogeekonline.net/galler...e_Liq_030b.JPG
And here are the results, a super high gloss shine that's slick to the touch.
http://www.autogeekonline.net/galler...ce_Liq_031.JPG
http://www.autogeekonline.net/galler...ce_Liq_032.JPG
http://www.autogeekonline.net/galler...ce_Liq_033.JPG
http://www.autogeekonline.net/galler...ce_Liq_035.JPG
http://www.autogeekonline.net/galler...ce_Liq_036.JPG
http://www.autogeekonline.net/galler...ce_Liq_037.JPG
http://www.autogeekonline.net/galler...ce_Liq_038.JPG
http://www.autogeekonline.net/galler...ce_Liq_039.JPG
Review
Nice product. When used correctly, and by the word correctly I mean clean, smooth paint, this product glides on and off super easy. It leaves the paint feeling very slippery, which is a characteristic of high quality waxes and sealants. There's no dusting and in our garage environment it dried to a haze in about 15 minutes.
Besides application and wipe-off, I think the really nice feature is the ability to resist high heat temperatures. Here in South Florida, it can be hot outside dang near every day. Even days when it rains, once the rain is gone the sun comes back out and pretty much bakes everything dry. So if you live in Arizona, New Mexico, the Mojave desert or anywhere in the sunbelt, this would be a great choice for your vehicles.
On Autogeek.com
http://www.autogeekonline.net/galler...ce_Liq_034.JPG
Re: Review: BLACKFIRE BlackICE Hybrid Liquid Wax
:bump:
Now available. Very nice product.
The perfect topper for BLACKFIRE One Step.
:dblthumb2:
Terrible timing!! Lol. Just bought the BF one step and needed a topper. Was unsure about using my trusty 1000p so I bought the sio2 spray. I’ll have to pick this up later. :(
Also Mike, how long does one step have to cure before you apply the hybrid wax?
Great review Mike. What is the difference between the Blackfire Hybrid Liquid Wax and the Blackfire Paint Sealant?
Quote:
Originally Posted by
Pats300zx
Not Mike here, but my guess is the Montan wax is the difference.
Unlike the BlackICE paste, this liquid doesn’t seem to include carnauba which would have been another difference
Does (or will) high heat melt wax off of your vehicle? I’ve never heard this. The engine alone puts out some high heat. I live in a high heat area and have never noticed the wax melting off.
I’ve read a lot of members noticing poor durability of carnauba waxes in high heat areas. These were mostly older threads, as maybe folks realize sealants and coatings work better in these environments with all the recent technology.
Sure, but this is a hybrid. Interested in the real world testing but I have faith the durability is decent based on the excellent reputation of BF products.
Nice review Mike and excellent results.
Interesting that its not a black liquid. Im thinking its a liquid version of BalckICE Hybrid Montan paste. Is it not the case?
