Re: Ceramic Coating Removal
M205 should remove it. Give it a test spot and see how it goes.
I removed month old 3.0 with essence by hand I then removed with boss 15 and yellow pads.
Quote:
Originally Posted by
The Guz
How would one know its gone though?
I know polish angel told me their finishing polish would remove a fresh coat of their cosmic glasscoat.
You’ll be good with 205. If you look closely you’ll see a difference in color.
https://uploads.tapatalk-cdn.com/201...e13d47bccf.jpg
Here’s a pic when I removed by hand with a green CCS pad (I think) and essence. You can Definetly she where it’s removed
Agree a light finishing polish will remove the coating. I've removed small high spots by hand and also done entire pannels easily with a machine.
With every coating I've removed, it is very obvious where the coating has been polished off. The non-coated area will often be a touch lighter in color (on dark color cars) and you'll be able to see the edges of the area you worked in the right lighting.
I easily removed CSL & EXO with a white pad and 205. You can definitely feel the difference by touch.
Anyone tried using Griot's FCC and yellow pad to remove a coating?
RZJZA80
No, but I guarantee it would.
