Re: Cleaning tires and rims
Your local chiropractor will love this method, there's plenty of brushes that can fit in crevices and clean the entire inner wheel barrel. You'll need to find the right set because BMW's kick out a lot of brake dust
That’s true cause I already see flakes. Guessing if you don’t clean them well it gets harder later as keeps piling. Not sure if taking wheel off and on is smart due to safety ( unless I get auto torque wrench) lol any recommendations lol
If your cleaning a car to go to a show, or the barrels need actual polishing then I take the wheels off.
Other than that, just buy a good set of wheel woollies, including one with a flexible handle, and a set of detailing brushes for lug nuts and super tight spots.
Just to chime in,
Quote:
Originally Posted by
DirtyCanuck
This :iagree:
I clean a LOT of wheels and tires.
Machine scrub tires
Wheel Woolies and Speedmaster Wheel Brush for wheels
Use GREAT products - great tire cleaner and a great wheel cleaner
I must have hundreds of pictures showing how I clan wheels and tires. Great tools and products enables you to do this job well in the shortest amount of time.
A good set of brushes are critical to keeping your wheels in good shape. The other side of that equation is actually cleaning them frequently so there isn't a buildup of brake dust and grime which can permantely damage the wheels.
For most of my family fleet, I simply wash them as often as needed. On my car I swap out winter/summer wheels each year, so the set coming off the car gets a deep cleaning before being stored for the season.
DirtyCanuck
I don’t go car shows but would you say taking tire of at least twice year to fully clean is not bad idea (more or less? What do you think
I know some gunk of stuff hissing in wheel well lol
Not a bad idea at all as long as your set up with a proper jack and jack stands so you can do it safely.
Only time i would be jacking up wheels is if i had a shop
For my personal vehicles, I clean the wheels and tires up very thoroughly when its time to rotate the tires. I'm not going to take them off just to clean, but while they're already off, why not?
