CQuartz UK applied with no prep work - how to best remove
It's too painful to describe how this happened but on a new white Audi CQuartz was applied yesterday with little to no prepwork beyond a basic car wash. I can see and feel contaminants in the paint. Strong claying seems to be removing the contaminants at the expense of marring. Would it be better to polish out the CQuartz instead of trying to "clay it out"? My concern is polishing something with containments clearly in the paint will make things worse.
Option A:
Iron X
Wash
Clay
Polish
Prep paint
Recoat
Option B
Iron X
Wash
Polish
Prep paint
Recoat
Re: CQuartz UK applied with no prep work - how to best remove
I would go with option A. Work with a surface as clean as possible when polishing. Then if you use a clay bar. Try claying in smaller sections and refold often. And have a great clay lube to minimize the clay marring. When you clay you would maybe see more clay marring in the coating. If you use a clay alternative. The same with working on smaller sections and rinse off the clay alternatives often. Also here make sure you use a good clay lube. And if it's the first time the clay alternative is used. Remember that it's needed to be breaked in on the glass first. So the protection film is worn off and it gets more sticky. If you don't break these in you can have a lot of clay marring before it's done if used on paint only.
The clay marring would be easy to correct when you polishing. But this is under normal use. If the contaminants is big and trapped into the coating. And you notice that's actually deeper kind of scratches than clay marring. Then I would stop and it's a little trial and error with getting the coating off. The solvents used to do this is very aggressive and to be handle with care and off the plastic trim and rubber seals. This we can take if you are haveing a big problem with the claying.
How will polishing with contaminants in the paint make anything worse? The coating is much softer than the clear. I'd think polishing should remove pretty much all of the coating. You could then start all over. Clay, polish and repapply the coating. If you really wanted to go slow you could clay, polish and then clay again.
Quote:
Originally Posted by
tcope
I was under the impression that the contamination would get smeared around and scratch the paint? Maybe I’m crazy.
Wax & Grease Remover (a solvent in a can/bottle), will remove most coatings if applied by hand with a towel a few times, and should get rid of the coating. I think it's worth a try because it's easier to decontaminate the paint without the coating on it.
expdetailing
I may have to try this or go straight to polishing as mentioned previously as using the clay bar is very very slow going.
tcope
Polishing will remove the coating, but why would you polish paint with bonded or embedded contaminants in it? The polishing step is intended to remove swirls and scratches in the clear coat, and due to the abrasives in the polish will also remove the coating.
Polishing is not the way to remove bonded contaminates. You will shorten the life of your pads if you are not polishing a clean contaminate free surface.
Tony’s advice is spot on, the OP should go with option “A.”
BadgerRivFan
I have tons of unused new polishing pads. Are there other negatives to polishing with contamination (I can see and feel it)? Perhaps throw the pads away after one panel/section?
With regards to why I would polish first, i would only do it in the interest of time as the claying is taking a long time.
big thank you for everyone’s response. I’ve been so distraught over this I couldn’t sleep last night.
What clay do you use?
There is a big difference between clays. And there are clays that are very effective to pick up contaminants. I use a clay bar not sold on AGO. But these 2 are simualar and very good. The prices is a little higher on these. But with stubborn contaminants you often needs less aggitations with a more aggressive clay bar. 3M Perfect-It III Cleaner Clay - 38070 and Meguiars Professional Detailing Clay – Aggressive - C2100. And a great clay lube is Dodo Juice Born Slippy Clay Lubricant Concentrate. If it would be me I would start with these and see how it works. Now you can have a problem with getting the contaminants that has been totaly sealed in by the coating. But those I would think is so small that they would not be a big problem when you get to polishing. And clean the pad thoroughly with a compressed air to blow off the pad with or a good pad brush. Inspect the pad after the test spot and see how it looks like with the contaminants and if you can clean them off.
3M Perfect-It III Cleaner Clay, 3m 38070, a paint-cleaning detailing clay that grabs foreign particles as it glides across the paint.
Meguiars Professional Detailing Clay Aggressive - C2100
Dodo Juice Born Slippy Clay Lubricant Concentrate, born slippy clay lube, detailing clay lubricant, clay lube concentrate
YouTube
Here is a thorough video about some ways to go. The last option that will be getting the coating off you do it on your own risk. As this will also impact on the clearcoat. So do as he do and step up in aggressiveness. And maybe with several applications of a wax and grease remover could be takeing off your coating as it's newly applyied. Last resort is the paint thinner. A 15 minutes video that is the basics on how you remove protection from your paint.
