Is a M22 1/4 male coupling the right size to
hook up a MTM PF22 to a 2000 PSI electric
Greenworks pressure washer?
Printable View
Bump
Check on the Obsessed Garage website. You can even send them a message and get a quick reply.
I just purchased the MTM Hydro PF22 Foam Cannon with the spray gun and fittings. It says on Amazon that the Greenworks is the same as my Troy-Bilt and uses the 3/8” Brass M22 at the gun inlet. If you search for the kit it shows photos of all the fittings. The fitting between the short gun and the foam cannon is 1/4", all the others for my setup are 3/8".
