1 Attachment(s)
Best Ceramic Coating Package?
Hello All,
I live in Toronto, Canada and have used Cquartz UK & Geyon Pure in the past. They both work good however they never seem to last through our winters with all the salt/grime (at least not the bottom half of my doors) also I daily the car and part it outside. So regardless of the winter issue that i don't think I can do much about I'm looking at these 3 consumer based ceramic coatings. One being GTechniq which I have never used but heard good things about. If your opinion which is best? Which will last the longest, Provide best gloss & Hydrophobic properties? They all seem to mention up to 2 years durability of course depending on environment & other factors.
Gyeon Q2 Syncro
GYEON Q2 Syncro
GTechniq Exo & Crystal Serum Light
GTechniq EXO and CSL Kit
Cquartz Uk 3.0
Cquartz UK Edition
Thanks for your comments
Re: Best Ceramic Coating Package?
Your coating might simply be contaminated. Have you tried doing a chemical decontamination on it?
A coating, even the consumer products is a semi-permanent product. Unless you polish it off, it is still there.
If it is contaminated, it will prevent it from being hydrophobic, which is usually what makes people think it is gone... it is not a wax, so lack of hydrophobicity doesn't have the same meaning with a coating.
From what I have seen in the extensive reseach I have done over the last 3 years, Gtechniq's products offer the best quality of products. So if you decided to re-coat the car at some point, you can't go wrong with Crystal Serum Light. Putting EXO on top will make the car more hydrophobic, but the durability should be about the same for the base product.
I can’t say about durability since it’s been only 5 months that I put Syncro on my car. So far, it’s been awesome. Water behavior is insane. I just washed the car and each time I do it puts a smile on my face. It’s like water and my car have same polarity and repel each other.
Well just my opinion. I don't think you will find a coating that will give you that hydrophobic
water behavior your are looking for on the side lower panels. like calendyr said your coating may just be contaminated, doesnt mean it still isn't there. i have tried cquartz UK and now have serum and exo
on my rx 350. after 2 years the water beading on the hood is fantastic but the side panels not so good.
This is why i am on the fence with coatings. Just not happy after a few months it feels like the side panels need to be clayed and water behavior isnt the same as when i first applied it. always make me feel the same way, is my coating still there. lol
Quote:
Originally Posted by
bryanviper
Hello All,
Harsh conditions are going to beat up on coatings.
A majority of the gloss will come from polishing.
Give it a decon wash and see if the coating can be revived.
From the coatings you are looking at, I was the least impressed with Syncro. It’s performance over a year was underwhelming and lack luster. Not worth the money if you ask me.
Cquartz UK 3.0 is a better choice as is CSL topped with Exo. CQUK 3.0 has a better self cleaning effect between the two but not by much.
yes I have, did a full Decon a few times and it only improved slightly. I even tried non diluted degreaser to see if that would do anything. The sides are definitely gone or at least not beading up like they should be,
Thanks
Calendyr
Had you tried any other coating before Syncro?
BSoares
Well I know when I apply a coating in the Spring/Summer the side doors are great, lots of hydrophobic properties & I would regularly add CarPro Reload. This would last for months during the spring/summer/fall.
Well in your case it sounds decent to me. The fact you are getting around 2 years which is what the coatings are generally rated for thats great. I'm lucky to get 1 year due to our winters.
asalesagent912
How often do you top? If often( every couple of months) Have thought of trying a better topper? Maybe give overcoat, PA Viking or IGL premier a try. Not cheap but one big bottle of any should last you a couple of years
Different chemicals desolves different kind of dirt and contaminants. Get a tar remover and you will have some of the water behavior back. Regualary wash with something like Carpro Reset car soap. I don't believe waterless wash or rinseless wash is enough cleaning ability in harsh winter weather environment. An alkaline based degreaser or citrus based degreaser or a dedicated prewash foam in combo with a tar remover and if necessary to do an iron remover too. If you have a lot of minerals in the water and or environment a water spot remover could be necessary too. It has come out some slightly acidic based car soap lately here in EU. Which helps a lot to revive the coatings when you use to touchless washes with water that has minerals in it. Coatings is very chemical resistant and only the extremly high alkaline products over ph12 and the extremly acidic based degreaser lower than ph3 is where you have to be carefull. Most solvents which most tar degreaser is based on is also coatings resist good. There are some solvents like some highly concentration of citrus oils and some hydrocarbon is aggressive on coatings. On the other hand most toppers use not only the coating chemicals and can be very effected of any degreasers. For an example Carpro Reloads use some oils in their formula and when useing TarX you desolve those so the gloss degrade then but the coating is not effected.
Just this weekend one posted an update on a Swedish forum about his CQUK the old formula. I got interested and asked some questions. He have topped with Reload and Merlins Elixir about every 2 months or so. And last Reload application was early december. The CQUK is 2 years old and still behaves on all surfaces around 70-80%. He was with Reset car soap only and use always a prewash foam that is slightly alkaline. If he needs and often during the winter months here in Sweden a tar remover. And he lives in a more harsher winter environment than me here in Sweden too. So even with degreasers used it holds up quite good I think. The thing is to not get the coating clogged to much before useing a chemical that desolves the reason why it's clogged. And that differs on the environment you live in and what products you uses too. I would go with a tar remover like TarX and see if you get the behavior back. If you have an iron remover test if you get any bleeding effect that will say if you have industrial fallout or iron particals on the paint. And mostly behind the front wheels and to the back of the car and half way up on the side panels you see most iron particals. If you have industrial fallout you have those mostly on the horisontall panels.
