Review: FLEX BW-18 Cordless Blower by Mike Phillips
The FLEX BW-18 Cordless Blower
http://www.autogeekonline.net/galler...FLEXCB_001.JPG
First here's the technical info and specs from the AG Store page
Brought to you from the same people that brought you the FLEX XC3401 – aka, the BEAST – the FLEX BW-18 Cordless Blower is the perfect addition to the FLEX collection. Featuring a brushless motor, a turbine fan, variable speed settings, as well as good balance and a lightweight build, the FELX BW-18 Cordless Blower is the easiest way to dry your car – in about half the time it would take to dry with a towel! You already use a FLEX polisher to rid your vehicles of shine-reducing swirls and scratches, make sure you have the FLEX BW-18 Cordless Blower for drying after a wash!
Wash with soap and sponge, dry with microfiber towel or chamois, wax with carnauba paste wax. That was the standard car washing method for decades – until new technology and advancements were made, of course! Thanks to the ever-evolving detailing industry, we’re seeing changes to that routine. Instead of a regular car wash, you can use an SiO2-infused wash. And now instead of using your hands and an old chamois to dry, you can use the FLEX BW-18 Cordless Blower!
FLEX BW-18 Cordless Blower Quick Look:
• Brushless motor.
• 3-speed electronic lock-on switch.
• Compact, handy. Lightweight design.
• Ergonomically shaped soft handle with on/off switch and lock for continuous operation.
• Removable blow tube and nozzle.
• LED battery capacity display.
• 3 airflow adapters included.
The FLEX BW-18 Cordless Blower, unlike standard big box leaf blowers, was designed specifically for the removal of water from your car’s painted, glass, and plastic surfaces. Featuring a brushless motor that promotes increased battery efficiency and a longer motor life, the FLEX BW-18 Cordless Blower is (obviously!) cordless and allows you to “cut the cord” so to speak while you’re drying! The high CFM turbine fan quickly blasts water away before it has a chance to dry – avoiding troublesome water spots completely!
Featuring a light-weight build with good balance, the FLEX BW-18 Cordless Blower is easy ergonomically sound and easy to maneuver around your car’s tight spots. No more water hiding behind decals and in doorjambs! With a max-MPH speed of 178.95 and a CFM of 3.1 m3/min that water will be gone before it knows what’s happening – and you barely had to lift a finger!
The FLEX BW-18 Cordless Blower is compatible with the same FLEX Batteries found with the FLEX Cordless Polishers and can be charged using the same chargers. The FLEX BW-18 Cordless Blower does NOT come with a battery or charger, but check out the FLEX BW-18 Cordless Blower Complete Kit for the Blower, a 5.0 Ah battery, a charger, extra nozzle accessories, and a storage/carrying case!
The FLEX BW-18 Cordless Blower Technical Specifications:
• Battery capacity: 2.5 or 5.0 amp Battery
• No load speed: 10,600/14,200/18,000 RPM
• Max air speed: 100 CFM
• Weight without battery: 2.65 lbs.
All good stuff.... now my turn to talk...
I've been answering car detailing questions professionally for 16 years now, going on 17 in a few weeks. By the word professionally, that means I get paid to answer questions. So here are the 2 most common questions I get,
Question 1: How do I remove the swirls and scratches out of my car's paint?
Questions 2: How to I avoid putting swirls and scratches back into my car's paint?
So the normal scenario goes like this,
A person joins our forum and asks how to remove the swirls, scratches, water spots and oxidation out of their car's finish. Myself and our awesome forum members answer their questions and guide them to the products and the procedures to restore a better than new factory finish. Then the next question the person has is now that they've done all the hard work and have a finish they are happy with.... how to keep it this way?
I always answer this type of question by saying that everything comes down to how you TOUCH the car's finish. Always obtain the highest quality products to wash and dry your car because this is where most swirls and scratches come from is via the washing and drying process (over time). So one way to dramatically reduce instilling swirls and scratches over time is to blow the water off your car instead of wiping the water off your car. This is where a car dryer or car blower comes into play.
Flex has just introduced a new addition to their family of cordless tools, the FLEX BW-18 Cordless Blower. Let's take a look....
First, the reason I put my name on this particular FLEX Cordless Blower or FLEX CB is because this was a personal gift to me from Bob Eichelberg, the President of FLEX Tools North America. This is a pre-production unit, the only one in the United States and possible the world. It has NO SERIAL NUMBER - Thank you Bob!
http://www.autogeekonline.net/galler...FLEXCB_002.JPG
The battery attaches to the bottom of the back and this actually makes the tool very well-balanced.
http://www.autogeekonline.net/galler...FLEXCB_003.JPG
The end of the blower housing is notched to hold and secure 4 different attachments....
http://www.autogeekonline.net/galler...FLEXCB_004.JPG
The primary attachment is soft rubber blow tube...
http://www.autogeekonline.net/galler...FLEXCB_005.JPG
There are three other attachments that are more suited for various blowing tasks...
http://www.autogeekonline.net/galler...FLEXCB_006.JPG
http://www.autogeekonline.net/galler...FLEXCB_007.JPG
Re: Review: FLEX BW-18 Cordless Blower by Mike Phillips
Continued....
Need a wet car!
I don't do mock-up. So in order to use this new tool I need a wet car and not wet from the rain. So I borrowed a Ford Escape I coated with GYEON One about a year ago. It's important that the paint on a car you want to blow dry is in EXCELLENT CONDITION maintained with a coat of wax, synthetic sealant or ceramic paint coating. I'll explain why when you get down to the pictures of water beading on the roof below.
Just by chance, my good buddy Rob McCrary gave me some NEW products introduced at SEMA a few weeks ago to test out. The Actifoam Energy foam soap may be available now and the Wash + Seal will be here this spring. More on these later, mostly just wanted to share some cool new products from SONAX.
Just to note - if you read enough of my how-to articles you'll ALWAYS see me using the Grit Guard Universal Detailing Car when I wash cars. The primary reason why is because it keeps my wash buck at waist level so no bending over. It also holds all my tools and I can push it around the car as I work around the car.
http://www.autogeekonline.net/galler...FLEXCB_008.JPG
http://www.autogeekonline.net/galler...FLEXCB_009.JPG
http://www.autogeekonline.net/galler...FLEXCB_010.JPG
http://www.autogeekonline.net/galler...FLEXCB_011.JPG
http://www.autogeekonline.net/galler...FLEXCB_012.JPG
http://www.autogeekonline.net/galler...FLEXCB_013.JPG
Always start with wheels and tires first
My favorite wheel and tires washing tools and products....
http://www.autogeekonline.net/galler...FLEXCB_014.JPG
http://www.autogeekonline.net/galler...FLEXCB_015.JPG
Not only is this softer than concrete it keeps your butt from getting wet when washing wheels and tires...
http://www.autogeekonline.net/galler...FLEXCB_016.JPG
Here's another tip for anyone that has a tall vehicle like an SUV - get two Werner Work Platforms and put them side by side and then you can walk back and forth on them as you work on the roof.
http://www.autogeekonline.net/galler...FLEXCB_017.JPG
http://www.autogeekonline.net/galler...FLEXCB_018.JPG
Mega foam that makes washing SLIPPERY!
http://www.autogeekonline.net/galler...FLEXCB_019.JPG
http://www.autogeekonline.net/galler...FLEXCB_020.JPG
http://www.autogeekonline.net/galler...FLEXCB_021.JPG
Continued....
Washed and Rinsed
Okay - I've washed the Ford Escape from bottom to top and back to bottom. Sorry no action shots but trust me.... I was the one doing the work.
Water beading
Below you'll see pictures of water beading. Look at them and after the last picture I'll explain what this means to you.
http://www.autogeekonline.net/galler...FLEXCB_022.JPG
http://www.autogeekonline.net/galler...FLEXCB_023.JPG
http://www.autogeekonline.net/galler...FLEXCB_024.JPG
Here's the deal....
Water blows off easy if there is high surface tension on the paint causing water to bead-up. Water beading is a sign of high surface tension.
Simply put, the water is TRYING TO GET AWAY FROM THE PAINT.
This means it will BLOW OFF fast, easy and effectively.
If you car's paint does not bead water then no blower is going to work. So keep your expectations real-world. If you want to blow dry your car then you must be the type of person that likes to take care of their car and this means regularly washing and also maintaining a coat of wax, synthetic paint sealant or a ceramic paint coating on the finish which creates surface tension and thus causes water to bead-up.
Make sense?
I just don't want anyone to have unreal expectations because there is a little science to this...
Continued....
Check it out!
http://www.autogeekonline.net/galler...FLEXCB_025.JPG
First I'm going to check my power supply...
http://www.autogeekonline.net/galler...FLEXCB_026.JPG
Half a charge, should be more than enough....
http://www.autogeekonline.net/galler...FLEXCB_027.JPG
Here's the on/off trigger
http://www.autogeekonline.net/galler...FLEXCB_028.JPG
Here's the trigger lock so you don't have to hold the trigger in the entire time you're drying the car....
http://www.autogeekonline.net/galler...FLEXCB_029.JPG
The FLEX Cordless Blower has 3 speed settings.... all the way back is low....
http://www.autogeekonline.net/galler...FLEXCB_030.JPG
The center position is medium....
http://www.autogeekonline.net/galler...FLEXCB_031.JPG
All the way forward is full power....
http://www.autogeekonline.net/galler...FLEXCB_032.JPG
And like the other FLEX cordless tools, the cordless blower has sexy striping....
http://www.autogeekonline.net/galler...FLEXCB_033.JPG
Continued....
Here's the final results for the Ford Escape - completely dried off and I never used a chamois. I did mist the exterior with Pinnacle Black Label Surface Coating and dressed the tires to complete the job.
http://www.autogeekonline.net/galler...FLEXCB_043.JPG
http://www.autogeekonline.net/galler...FLEXCB_045.JPG
Review
First this is not the most powerful car dryer on the market but the cordless feature made it my favorite car dryer on the market. The soft rubber blow tube is nice in that it won't scratch the paint if you accidently bump in to a body panel, which I did a few times. As long as you maintain your car with something, wax, sealant or paint coating and water beads up it has more than enough power to blast the water off the body panels and just as important out of all the nooks and crannies. It's a lot more quiet than most and I don't feel the need to wear any ear protection. The 2.5 Amp batter with half a charge was enough to dry the entire car but normally I like the larger 5 amp battery for all my FLEX cordless tools.
This is a super high quality tool like all FLEX tools and my new favorite car dryer.
On Autogeek.com
http://www.autogeekonline.net/galler...FLEXCB_044.JPG
***Update***
Available now for pre-order
:dblthumb2:
Great review Mike. The fact that it’s cordless has definitely got my attention. I see you said it’s not the most powerful, but how powerful is it in comparison to say the Metro Sidekick and/or the McKee’s blower?
Thanks for the review Mike. Being cordless is an attention grabber. Also the fact that these utilize the same batteries as their cordless polishers is a good idea.
Does this run quieter than say the McKee's or Blackfire blowers?
OH NO.
Another Flex tool that I may want.
