Re: A bit disappointed...
Did you add the washers included with the polisher? If you did and it is still not freespining, call Autogeek or Griots. They both have excellent customer service and will make it right. I had the same issue and they exchanged it for me.
Sent from my SM-N950U using Autogeekonline mobile app
If you decide to add the washers, start with just 1 at first to see if that gives you enough wiggle room. Also, don’t forget to lube the edge of the shroud with the silicone grease provided. Just a lil on the rim.
Appreciate the replies. I hesitate to say something is actually wrong with the polisher because it's new to me and I don't know if this is normal. I've been reading some previous posts about the Griots Boss polishers (which I should have done before my purchase) needing to be modified with the washers and I guess I'll give it a try but it's still disappointing that a brand new out of the box tool needs to be modified by the customer in order to work properly. These polishers have been out for about three years now and apparently Griots does not feel this is an issue.
Adding a single washer will help a lot. It did for me. Give it a try and let us know if you have better results.
ScottH
I don’t use any washers in mine. IMO it runs smoother without the washers installed.
Long throw polishers are known to stall much easier than short throw polishers, so I don't think anything is wrong with your polisher, you just need to adjust your technique and concentrate on keeping the backing plate moving and not just wiggling.
Without the washers it won't freespin much, if at all. With the washers installed it will freespin some, but you won't need to lube anything since the backing plate no longer touches anything.
I have the G21 and bought it when it first came out. Never had that issue on flat panels. It's my go to swirl killer if I need more aggression than my Rupes Duetto. I run a 5" BP on it, no washer mod.
Just for the sake of covering all the possible reasons as to why you could be experiencing less than expected performance from your new polisher, are you connecting it directly into a wall socket? Or through an extension cord? They recommend using at least a 14 gauge cord if it’s 50’ length for optimum power of the polisher. Small chance of this making a dramatic difference, but it is possible.
Quote:
Originally Posted by
Eldorado2k
I do this to ALL our long throw polishers with shrouds. A "must do".
RZJZA80
Somewhere I have an article on this topic - it's about how the simple 8mm free spin polishers are less likely to stall out than any long stroke polishers. Can't think of the name but if anyone can find it I'll send you a "surprise" for find it and sharing it.
