Review: Machine Tire Scrubber by Mike Phillips - NO SHOCK HAZARD WHILE WASHING YOUR CAR!
Recently we brought in a cordless spot repair polisher and I was asked to test it out. I charged the battery and the affixed a couple different types of buffing pads, placed it against a body panel turned it on a just as expected, the little hand held drill looking tool spun the pad against the paint. I sent in my feedback that the tool did in deed work to buff paint but what where I think it really shines, (no pun intended), is as shock-proof machine tire scrubber.
What am I talking about?
I'm talking about machine scrubbing your tires instead of hand scrubbing and I'm talking about using this little handheld cordless polisher as a machine tire scrubber. You see, this tool unlike a drill uses an attatchment design that uses a 5/16" fine thread spindle not a universal adjustable chuck like most drills.
Guess what?
The Cyclo brushes have a 5/16" fine thread spindle. This means they will thread onto this cordless polisher and turn it into a cordless machine scrubber.
Check it out...
Here's an old 2-door Chevy with some period correct tires....
http://www.autogeekonline.net/galler...rubber_001.JPG
Here's the Mighty Mini Cordless Polisher with a Cyclo Aqua Upholstery Brush
http://www.autogeekonline.net/galler...rubber_002.JPG
Picture kind of does the talking...
http://www.autogeekonline.net/galler...rubber_003.JPG
And here's the deal.... machines always outperform the human when it comes to most detailing procedures....
http://www.autogeekonline.net/galler...rubber_004.JPG
SAFE WAY TO MACHINE SCRUB TIRES
And besides doing a better job of getting the brown tire blooming off your car's tires as well as just about everything else, because this tool is CORDLESS you cannot get shocked while machine scrubbing your tires.
Shocked you ask?
Yes, shocked. I can remember being shocked while machine scrubbing some tires on a Ferrari in the below article, check out the 2nd and 3rd picture. Note there's no water on the ground in this pictures. The shock came when I learned the importance of washing the downhill tire FIRST, not the uphill tire.
How to wash Ferrari Wheels and Tires
I don't know if I'm the original source for showing people how to turn their Porter Cable 7424 Dual Action Polisher into a dual action tire scrubber but I have the oldest article I can find on this topic on the Internet. The time stamp on this article is March 28th, 2013
Best darn tire cleaning brush I've ever used!
Here's the first video I made on this procedure dated October 25th, 2013 --> Screenshot
https://www.youtube.com/watch?v=cxO6u2xSbIo
Rotary vs Orbital
Another benefit to this tool is that it is a rotary action, that is the brush is spun in a single direction and like all drills the power is delivered via gears, that is it is gear-driven, not free spinning. ANYONE that has ever used a Porter Cable or Griot's Garage or any copy of these two tools to machine scrub tires knows two things,
1: Just like polishing paint with a free spinning polisher you have to turn the speed up to the highest setting and pay attention to how you hold the polisher to maintain BRUSH rotation. Not so with this cordless tool, it's gear driven and the brush always spins.
2: When you use an orbital polisher to machine scrub the portion of the tire that's close to the concrete, the reciprocating backing on the brush bangs into the ground and makes a horrible sound plus vibrates the heck out of your hands. Not so with this cordless tool.
Machine scrubbing your tires is the only way to go....
On Autogeek
Mighty Mini Cordless Polisher aka Machine Tire Scrubber
2 Pack Cyclo Polisher Aqua Soft Carpet Brush
TUF SHINE Tire Clearcoat 16 ounce
Re: Review: Machine Tire Scrubber by Mike Phillips - NO SHOCK HAZARD WHILE WASHING YOUR CAR!
I see this tool in my future. I love machine tire scrubbing. But with a cordless gear-driven tool...BONUS!!
Awesome Stingray and cool tool for scrubbing tires. I bet it works just as well on floor mats and carpet.
When AG announced this tool, it was the kit with the brushes that caught my eye. I was wondering which one would be best for tires. Should be a good carpet tool.
Mike, can we assume that there was plenty of battery power to clean the four tires? Can you give an opinion on the battery time? Should one assume that an extra battery be a requirement?
Continued....
Here's some more info....
It comes with the tool, two batteries and the charger.
http://www.autogeekonline.net/galler...rubber_005.JPG
This is the threaded chuck, it's 5/16" fine thread
http://www.autogeekonline.net/galler...rubber_006.JPG
http://www.autogeekonline.net/galler...rubber_007.JPG
All Cyclo brushes have a 5/16" fine thread spindle or stud for attaching to the Cyclo Polisher.
http://www.autogeekonline.net/galler...rubber_008.JPG
On the top of the chuck is a gear-lock button to lock up the gears while you tighten on the brush or any backing plates.
http://www.autogeekonline.net/galler...rubber_009.JPG
On the top of the handle is a speed selector with options for speed #1 or speed #2
http://www.autogeekonline.net/galler...rubber_010.JPG
http://www.autogeekonline.net/galler...rubber_011.JPG
There's also a slider switch on the side to lock the power button in the on or off position.
http://www.autogeekonline.net/galler...rubber_012.JPG
http://www.autogeekonline.net/galler...rubber_013.JPG
The rechargeable batteries are the normal stile for small tools and install and remove easily.
http://www.autogeekonline.net/galler...rubber_014.JPG
There are 3 battery life indicator lights on the side of the tool that light up to show current battery charge when you pull the speed trigger.
http://www.autogeekonline.net/galler...rubber_017.JPG
http://www.autogeekonline.net/galler...rubber_018.JPG
When installing a Cyclo brush, press the chuck lock-up button and then spin the brush on and tighten until snug.
http://www.autogeekonline.net/galler...rubber_015.JPG
My new best tire scrubbing friend...
http://www.autogeekonline.net/galler...rubber_016.JPG
OK never mind. So it already comes with 2 batteries.
Quote:
Originally Posted by
DBAILEY
I machine scrubbed the 4 tires on the Corvette and the 4 tires on my own car without changing the battery and without noticing any falloff in power from the battery in the tools.
This really makes scrubbing your tires FAST and EASY. Worth every penny if you're a fanatic about clean wheels and tires. Plus I don't have to worry about being shocked. In ALL my articles, video and in all my classes over the past 5+ years, I've always used myself and shown others how to machine scrub tires using a tool MOST people already have, a Porter Cable or Griot's Garage or even the HF polisher and it's because the Cyclo brushes will attach like a backing plate.
The issue has always been to NOT have the water hose around until AFTER you have done the work because there is no such thing as a water-safe corded electric tool. That said, I still preferred to machine scrub tires versus hand scrub so I'm always very careful and I warn others to be careful.
So when I first was shown this tool as saw that it could take the Cyclo brushes my first thought was not polishing paint, I have normal polishers for that, my first thought was,
Wow! A safe way to machine scrub tires!
And with 8 tires under my belt it is now my go-to tool for scrubbing tires anytime I wash a car.
Here's a technique tip....
Put the speed setting on the #1 - that's the slow setting and don't simply pull the trigger full power. Instead, feather the trigger a little to spread your tires cleaner over the sidewall and then only pull the trigger half way. Half a trigger on the #1 speed setting is more than enough power to machine scrub tires effectively.
I also used to machine scrub the plastic cladding on our SUV. Works like a charm.
Works good.
Also - for anyone considering applying a tire COATING to their cars tires or their customer's car's tires should be machine scrubbing the sidewalls to insure they are completely clean and free of anything that could interfere or hinder with the bonding of the coating to the rubber.
I don't think I would ever attempt using a tire coating unless I had machine scrubbed first.
Continued.....
Works great to machine scrub plastic trim and cladding....
http://www.autogeekonline.net/galler...rubber_019.JPG
My camera lens was fogged over when I took this shot but this is machine scrubbing the lower plastic trim on the bottom of the passenger side rear fender...
http://www.autogeekonline.net/galler...rubber_020.JPG
This would be good for removing oxidation off of neglected exterior plastic before applying products like Solution Finish or other plastic trim dressings. The key to using a trim dressing or protectant is to FIRST get the weathered, neglected trim very clean.
Mike! Stop making me want to spend money LOL
This looks very nice. Just added it to my wanted list ;)
Calendyr
So far this tool has worked out really well as a machine tire scrubber. At least that's how I like to use it. I've been showing it at all my detailing classes, both the big 3-day here and the 2-day classes on the road.
I just included some tips for using it here,
Review & How-To: Pinnacle Advanced Tire Cleaner
See post #3
Mike Phillips
See post #3
Thanks to your review, Mike, I ordered one! I already had the scrub brushes from before.
Haven’t had a chance to use it yet due to tires being relatively clean. But, I’m planning to use them to scrub and then coat a set of tires on my DD.
[emoji106][emoji2533][emoji106][emoji2533]
VitreousHumor
Good to hear.
When I use this tool, first make sure the batteries are fully charged. Next, be sure to TIGHTEN the brush into the chuck, otherwise it can and will spin off.
Then when using it I rarely just pull the trigger and scrub, instead I kind of feather the trigger and just work a section at a time. It works best to go ahead and just sit your butt down in front of the wheel when using this tool so you're looking straight across from it.
It's also easier to use it when holding it with both hands. I only show using it with one hand because my other hand is holding a Canon Rebel T6i taking the pictures.
Excellent!!
Thank you, Mike!
[emoji16]
Mike Phillips
Good to hear.
Didn't know this existed, I cleaned a neighbors tires on their super raised f250 FX or whatever the heck he has. Absolutely GINORMOUS tires. I used the Tuf Shine brush + Tuf Shine cleaner and after 4 sessions the foam was still not white, so I gave up. Tires weren't even that dirty (at least looking) and he doesn't off road. I think this tool could have given me white foam in 2 passes. Scrubbing tires isn't fun, and even with a good cleaner like Tuf Shine, it can take half a dozen cycles to get them white foam clean. This machine can be used on carpet too? For the price it seems like a no brainer. It's definitely on my Xmas wish list.
Just to note - I like the $500.00 FLEX PE14 better but if it’s not available to me I would gladly use the Mighty Mini.
One thing about the Mighty Mini - it shuts off on its own when using. Not sure why but seems to happen to all of them.
Just release the trigger and then squeeze it again and it comes back on.
I show it in all my classes including the one I’m flying to right now. I also shared this with everyone in the class. I want them to know it shuts off so they are not disappointed in me.
so I have looked around and cannot fin the brushes separately. Not for Auto Geek, where I ordered the Mighty Mini, or Amazon (did google search with no luck either). You can however order another 150.00 unit to get different brush styles at Auto Geek, but i'm not gonna try that way.
Any sources you can share here?
Thanks, much appreciated.
PSI did order the MM with the Leather Complete Kit (with the blue brush as you show for tires, IIRC also with the leather kit) I need a backing plate for the pads from Auto Geek, not 100% sure the tool includes the plate or not. Be nice if it does. Everything seems to be a la carte with their catalog/website (Auto Geek). Don't get me wrong they have a great section.
okay. i found where the DA brushes were hiding on AG site. I might have seem them before, I just didn't understand fully the way in which they were attached. I knew it was not a drill chuck, but now I get it. I will see if the kit come with a pad backing plate (assuming, up we know ASS U ME is not always best policy), if not I might run to Northern Tool and see if they have something that might work if I am in a rush to try other things out and not want to wait for another order to ship, I am pretty sure I saw some polisher items in the place somewhere.
Thanks
DGatlanta
Good to hear.
There's a LOT of stuff on the AG Store and that can make it difficult to find things.
Reminds me of how people use to complain because there are too few choices, now people complain because there's too many choices.
:dunno:
Also works great around the boat. Used on our Cobalt I/O ( algae removal from swim deck platform, Volvo outdrive, etc) ; great for small areas.
Markymapo
Thanks for sharing.
I (finally) ordered the Mighty Mini along with the Cyclo brushes for machine scrubbing my tires today. I've wanted to get this set up ever since Mike first started this thread back in 2018. The Mighty Mini is never discounted, so I purchased discounted Autopia gift certificates back at Christmas time knowing that I would order this battery-operated polisher in the spring. Well, today was the day!
Looking forward to retiring my tried & true Tuff Shine brush... :)
I love my mighty Mimi. It’s the best
Ancient1
It looks like my M12 with a brush.
It does look similar.
Seems like a lot of tools look similar now days.
