Add "only" hydrophobic property to my paint?
I am currently running with Optimum Synthetic Spray Wax on my new car. The front end is protected with Suntek Ultra. After reading ad nauseam about ceramic coatings and their reload products, I settled for my old school OSW. My question for the forum is are there good options for adding just hydrophobic action? Ideally on top of my OSW... I noticed that all the ceramic coatings tend to lose their hydrophobic qualities first and then people add that back via some product. I just want more hydrophobic action only. I recently tried using my OSW as a drying agent while I was drying it and felt like I was buffing more than I prefer and worry drying with too much effort will give me swirls... Any ideas?
Re: Add "only" hydrophobic property to my paint?
Quote:
Originally Posted by
Insaneoctane
...are there good options for adding
top of my OSW...
Any ideas?
:idea:
Use Optimum’s Opti-Seal for your
“drying aid”—(as well as for several
other detailing tasks).
[However, (and knowing full well that you
only want more hydrophobic action), I feel
I would be amiss if I didn’t add a few words
of “Caution”: Opti-Seal will also provide some
(additional) protection. Drats!?!?]
http://<br />
<a href="https://m.you...k">YouTube</a>
Sonax Brilliant Shine Detailer is a QD that leaves a very hydrophobic surface. Some don't like it cause it leaves a little grabby feel when you touch your paint. IME it don't interfear with the washing and drying and just when you touch it with your hands it's not that slick feeling. Still it's leaves a great aggressive water behavior and self cleaning ability from it. And it leaves protection behind and a crispy look from it. I prefer to apply it on dry paint but can be used as a drying aid too. A little product goes a long way. 2 sprays on the bigger panels and 1 spray on the smaller panels.
Then you have the ceramic toppers that leaves a very hydrophobic surface. Gyeon Cure and Carpro reload and gtechnic c2v3 and McKees 37 Extended Spray Wax. And alot of others both with sealants ability in longevity part. Spray on rinse off coating topper.
I am not a fan at all of OptiSeal as a drying aid. Far too streaky IMO. It's better applied in my experience after the car is dry, one spray per panel (two on larger ones) with a MF towel to distribute and buff. It's probably the most compatible product as FUNX650 alluded to.
Any spray sealant will fit this bill really. Just be aware that the more beading ability it has, the more likely it is to water spot if the car is a bit dirty/dusty especially with pollen. Some examples:
-Gtechniq C2V3
-Gyeon Cure
-Carpro Reload
-CG v07 (if you feel like reapplying every week)
I've also heard good things about P&S Beadmaker but haven't tried it myself.
A better option honestly would be something like Mckee's Hydro Blue, Gyeon Wet Coat, or Sonax Spray N Seal but that would potentially negate the optimum wax you're using.
Opti-Seal
Duragloss Aquawax
Meguiar's Ultimate Fast Finish
Out of all the above, Duragloss Aquawax is the slickest, and beads like crazy.
+1 for Sonax Brilliant Shine Detailer
acuRAS82
Guys in the Burgh think alike :)
I also like their new spray sealer also...
Thanks for the inputs....
I noticed the Duragloss aquawax is significantly cheaper per oz. than the opti seal. I would be lying if I didnt admit that helps. The comments about how opti seal can be streaky are a turn off (even though I love Optimum products). Would DAW be a decently compatible product on top of my OSW? I already have a gallon of OSW, and like it, so if I can add hydrophobosity with just a topper, that's great! Is it one of the easier sealants to apply?
PS- which would give better water action, Sonax or Duragloss?
Its only streaky in my experience when used as a drying aid. When used normally I love it.
Are you not getting water beading with Optimum Car Wax?
Take a look a Ultima Acrylic Spray Wax--very slick, very hydrophobic and lasts longer than OCW.
