Originally Posted by
acuRAS82
Hobbyist here. I cant say if your second Klasse penetrated through the first coat residues. As I mentioned though, you should have even coverage regardless. I’ve never used Klasse but I’ve used many others and I don’t believe in layering the same thing more than twice, because two times gets even coverage.
Anything more, and it’s anyone’s guess as to whether your helping, hindering or just not doing anything to the existing LSP.
Collinite can be topped on most anything and should change the look a bit. You can apply that anytime after how many layers of Klasse u decided on have cured (10 hours after the last coat was buffed off, I believe is what u said before).
