Brand Spotlight: Tornador -Plus- 20% off
https://lib.store.yahoo.net/lib/auto...DOR20-NLSP.jpg
*20% Off Coupon Code TORNADOR20 valid on in stock items. Not applicable on previously placed orders, custom or special order items, extractors, air compressors, BUY ONE GET ONE, VIP Special, car covers, polishers & polisher kits, vacuums, Kreepstool, FlatStoppers, Shop Air Heavy Duty Drum Fans, vapor steamers, garage flooring, gift certificates, bulk and case pricing, complete wash systems or any item as noted on product page. One coupon code per order.
*Free Shipping applies to orders over $125 with ground service within the 48 contiguous United States. Regular shipping charges apply to garage flooring and mats, air compressors, and carpet extractors as noted on those products. Regular expedited charges apply.
https://sep.yimg.com/ca/I/autogeek_2269_117663844
Tornador Car Cleaning Tools & Air Foamer
The Z-020 Tornador Black has newly developed rotational technology inside the funnel to provide faster, more powerful cleaning compared to the Tornador Classic. Professional detailers will love the speed and effectiveness of the Tornador Black. The new design reduces wear and ensures a longer life and superior performance.
The Z-020 Tornador Black produces enormous power with a very small air compressor. All you need is a compressor with a discharge rate of at least 270 l per minute (4.5 cfm). This can be achieved using compressors with a reservoir of as little as 13 gallon capacity. Mobile detailers can now use the Tornador Black with a smaller, portable air compressor.The Z-020 Tornador Black is less noisy, too. The designers increased power but reduced air consumption and noise. Plus, the Tornador Black d is equipped with sealed ball bearings inside the rotation set. Wear is minimized because the rotation set no longer comes into contact with the cone. This improvement makes the Tornador Black better suited for long term, frequent use, as in a professional detailing capacity.Tornador Black features:
- Double the power of the Tornador Classic
- Low wear and maintenance
- Lower air consumption
- Suitable for 240V compressors
- Lower noise emissions
The Tornador Black Z-020 can be used for all the same applications as the Tornador Classic, but the Black is more effective on persistent spots, like chewing gum. The cone-shaped nozzle and oscillating tip create a tornado cleaning action that cleans hard and soft surfaces like nothing you’ve seen before. Dirt and grime are immediately released from fabrics, carpet, and solid surfaces.The Tornador Black Car Cleaning Gun releases a fine mist of cleaning solution that does not over saturate surfaces. You’ll see the liquid turning dirty as grime is released from the surface. Wipe with a microfiber towel. Then turn the dial to shut off the water and use the compressed air to dry the cleaned area. It’s that simple.
Use the Tornador Black Z-020 on the dashboard, door panels, steering wheel, fabric upholstery, carpet, floor mats, and between seats. It cleans in tough-to-reach places between seats and in seams. Because it releases so little liquid, surfaces dry quickly.
https://lib.store.yahoo.net/lib/auto...or-black-1.jpghttps://lib.store.yahoo.net/lib/auto...or-black-2.jpg
https://lib.store.yahoo.net/lib/auto...or-black-3.jpghttps://lib.store.yahoo.net/lib/auto...or-black-4.jpg
The Tornador Black cleans air vents, headliners, wheels and carpets.
On the exterior, use the Z-020 Tornador Black to clean fabric convertible tops, body seams, wheels, and emblems. There’s no need to scrub. The Tornador does the hard work for you.The Z-020 Tornador Black has an air regular to allow you to change the working pressure directly on the tool and also to dose the capacity of chemicals accurately. What this means is that you can use more pressure and cleaning fluid on tough spots.To clean any surface, dilute the desired cleaner according to label’s directions. Turn the liquid valve straight up and use an overlapping motion as you pass the Tornador Car Cleaning Gun over the surface. If necessary, allow the cleaning liquid to dwell for 10-15 seconds. Use a microfiber towel to absorb excess liquid. Then turn the liquid valve off and use the compressed air to dry the cleaned area.
The Tornador Black Car Cleaning Gun is not a foam gun. It is a patented cleaning gun designed to remove soil with a unique cyclonic cleaning action. There's nothing else like it!
https://youtu.be/Q7w8A1m5UtE
https://youtu.be/xYJjbo3MNLs
https://youtu.be/MJUzRyIa7qo
https://s.yimg.com/aah/autogeek/blac...ning-kit-8.gif
BLACKFIRE APC All-Purpose Cleaning Kit
Our Price: $277.96
Sale price: $225.00
