First time Cquartz UK application. Feeling sticky
I preppped a portion of my car. To get a hang of the coating. When I applied it, it was feeling very sticky. The applicator was sticking to the paint. I read in one of a thread that it does not need to flash before wiping. Wiping was easy. No stickiness in that.
Am I doing anything wrong?
Re: First time Cquartz UK application. Feeling sticky
what's the temp and humidity like where you're applying?
Temperature must have been around 30 degrees C. Humidity not sure. But must not be on higher side.
That's what, 86 degrees F? Sort of high for CQUK
Oh! Whats the ideal temerature then? Can i coat the car at night time?
Quote:
Originally Posted by
SArao
What did you do to prep the paint?
Washed the area. Used Meg Compound. Washed again. Used Carpro Essence. And then coating.
SArao
Your prep sounds ok. Maybe thinner coats. Sometimes I even get heavy handed which will cause the coating to get grabby.
May be due to small area I poured kess cquk. Will check again when i will be sure about coatingthe whole car.
At that temp just do a small area. You need to work fast in the Warmer/humid temps. It will flash quick. CQ’UK’ was designed originally for cooler/damper climates like the ‘UK’. I used it on cars in Florida, but had to do little areas at a time.
Sent from my iPhone using Tapatalk Pro
