Blackfire has new products!!
NEW FROM BLACKFIRE!!!!
Starts removing stains in seconds!
BLACKFIRE Carpet & Upholstery Cleaner will allow you to quickly and effectively remove stains, mud, grime, dirt, and other unsightly contaminants from carpet and upholstery. BLACKFIRE Carpet & Upholstery Cleaner will go to work within seconds of contact allowing you to expedite the detailing process. BLACKFIRE Carpet & Upholstery Cleaner will not stain or degrade the carpet fibers while it is removing difficult debris. BLACKFIRE Carpet & Upholstery Cleaner will work effectively on any type of non-suede carpet or upholstery you come across.
https://sep.yimg.com/ay/autogeek/bla...cleaner-12.gif
Our Price: $24.99
BLACKFIRE Carpet & Upholstery Cleaner 128 oz.
Our Price: $49.99
You can’t get the perfect finish without the perfect prep!
BLACKFIRE Paint Prep is a pre-coating prep spray designed to remove all polishing oils, synthetic fillers, light dust, and fingerprints from a surface before the application of a paint coating or last step product. BLACKFIRE Paint Prep is a simple spray and wipe, advanced formula that will not mar or scratch the surface during use. The key to a perfect paint coating application is the prep – and BLACKFIRE Paint Prep is just what you need!
https://sep.yimg.com/ay/autogeek/bla...nt-prep-12.gif
Our Price: $24.99
BLACKFIRE Paint Prep 128 oz.
Our Price: $59.99
What bugs!?
BLACKFIRE Bug Remover is a gentle cleaning formula that will safely and effectively remove insect remains from your vehicle’s paint, glass, plastic, vinyl, and aluminum surfaces. BLACKFIRE Bug Remover is concentrated to double your cleaning power with just one spray and can be tailored to meet your specific needs. Use BLACKFIRE Bug Remover as a spot treatment immediately after contact, or as a pre-treatment to make your washes even more effective!
https://sep.yimg.com/ay/autogeek/bla...remover-12.gif
Our Price: $32.99
BLACKFIRE Bug Remover 128 oz.
Our Price: $57.99
Because even your engine needs a little detailing every now and then!
BLACKFIRE Engine Degreaser is a non-toxic, biodegradable formula used to remove crud and oil from your engine and surrounding areas. BLACKFIRE Engine Degreaser uses a gentle formula that will not harm your engine’s components or the paint, plastic, and glass surrounding your engine compartment. Engine bays are a dirty area – they’re exposed to oils, dirt, grime, and all sorts of other crud – but BLACKFIRE Engine Degreaser will get that cleaned in no time!
https://sep.yimg.com/ay/autogeek/bla...greaser-15.gif
Our Price: $24.99
BLACKFIRE Engine Degreaser 128 oz.
Our Price: $57.99
Sale price: $48.99
A complete leather detail in one step!
BLACKFIRE Leather Complete will allow you to condense every step of your leather detailing process into one easy step. BLACKFIRE Leather Complete will effectively clean your leather while not damaging the very delicate surface in the process. BLACKFIRE Leather Complete will condition your leather, restoring it to a supple, soft, and better than new condition. BLACKFIRE Leather Complete will leave a durable level of protection behind after application to prevent the onset of further damage in the future.
https://sep.yimg.com/ay/autogeek/bla...omplete-12.gif
Our Price: $24.99
BLACKFIRE Leather Complete 128 oz.
Our Price: $59.99
PLUS HERE ARE SOME PRODUCTS COMING SOON!!!
BLACKFIRE Pro Ceramic Coating is unlike any paint coating ever before seen in the BLACKFIRE line. Designed to provide up to 2 years of protection, gloss, and depth, BLACKFIRE Pro Ceramic Coating creates a hard barrier between your paint and the elements. Using advanced ceramic paint coating technology, BLACKFIRE Pro Ceramic Coating was designed for easy application both by detailing enthusiast and professional detailer alike. Keep your paint protection, shining, and repelling water with unparalleled longevity with BLACKFIRE Pro Ceramic Coating.
Stay tuned for more information on BLACKFIRE Pro Ceramic Coating!
https://sep.yimg.com/ay/autogeek/bla...coating-41.gif
BLACKFIRE Pro Ceramic Coating COMING SOON!
Our Price: $64.99
BLACKFIRE Coating Applicator was optimally designed for the perfection application of BLACKFIRE Pro Ceramic Coating. Constructed using a thick polyurethane handle for enhanced grip on top, and a soft, open cell foam on the bottom, the BLACKFIRE Coating Applicator promotes an even application of product and provides a strong base when wrapped in a BLACKFIRE MicroSuede Cloth. The application of paint coatings can be tricky enough sometimes, don’t hamper your results with sub-par tools – pick up the BLACKFIRE Coating Applicator today and achieve the best coating results you can!
Stay tuned for more information on the BLACKFIRE Coating Applicator!
https://sep.yimg.com/ay/autogeek/bla...ng-soon-13.gif
BLACKFIRE Coating Applicator COMING SOON!
Our Price: $3.99
BLACKFIRE SiO2 Spray Sealant is the easiest spray sealant you’ll ever use! Designed with a spray-and-wipe application on freshly cleaned and coated paint, BLACKFIRE SiO2 Spray Sealant provides long-lasting protection thanks to the unique SiO2 chemical make-up. BLACKFIRE SiO2 Spray Sealant, typically used to extend the life and water-beading capabilities of your existing paint coating, can also be used as a stand-alone protection product. BLACKFIRE SiO2 Spray Sealant was designed with the professional detailer in mind and allows for quick application and long-lasting results.
Stay tuned for more information on BLACKFIRE’s most exciting new product – BLACKFIRE SiO2 Spray Sealant!
BLACKFIRE SiO2 Spray Sealant COMING SOON!
Our Price: $47.99
BLACKFIRE SiO2 Spray Sealant 128 oz. COMING SOON!
Our Price: $125.00
BLACKFIRE Pro Primer Polish is a non-abrasive, non-solvent polish used to prep your paint for the proper bonding of paint coatings. Designed to be use in conjunction with BLACKFIRE Pro Ceramic Coating, BLACKFIRE Pro Primer Polish uses advanced ingredients to remove all types of compound oils, previous waxes and sealants, and anything else that will prohibit the coating from performing its best. If you want the best results with coating with BLACKFIRE Pro Ceramic Coating, you’ll need the BLACKFIRE Pro Primer Polish first.
Stayed tuned for more information on BLACKFIRE Pro Primer
BLACKFIRE Pro Primer Polish COMING SOON!
Our Price: $59.99
BLACKFIRE Pro Primer Polish 128 oz. COMING SOON!
Our Price: $199.99
Keeping in line with the rest of the BLACKFIRE line, BLACKFIRE Multi-Surface Dressing was manufactured and designed with professional detailers in mind. This concentrated formula let’s the user decide the level of gloss, while still providing long-lasting, exception results. Featuring a versatile formula, BLACKFIRE Multi-Surface Dressing is used on leather, rubber, plastic, and even engine components, providing everything from a high shine to a muted stain finish.
Stay tuned for more information on BLACKFIRE Multi-Surface Dressing Concentrate!
https://sep.yimg.com/ay/autogeek/bla...centrate-9.gif
BLACKFIRE Multi-Surface Dressing Concentrate COMING SOON!
Our Price: $37.99
BLACKFIRE Multi-Surface Dressing Concentrate 128 oz. COMING SOON!
Our Price: $105.00
Re: Blackfire has new products!!
Would be happy to test any products
Quote:
Originally Posted by
atgonzales
Me too!
David
I wanted to start a thread asking, "What is the best cleaner for removing general dirt, light stains, AND IS EASY TO RINSE from a cloth interior."
I would be thrilled if BlackFire's new cleaner fit these wants.
Any idea what the SiO2 content for the coating is? There are so many coatings to choose from now manufacturers need to differentiate their coatings from the rest on the market.
The Blackfire Brand is one of the best under the PBMG umbrella. I like the brand BETTER than Wolfgangs! But as always thanks for the heads up!
Does the Sio2 spray sealant have to be used on wetted paint? Will it streak on dry paint? Can it be diluted with water and used on clean dry paint?
I am a fan of both the Blackfire and Wolfgang products. The Blackfire BF-450 APC was received as a free sample and I have been hooked on it ever since. It is a superb cleaner. I also recently purchased the foam soap and water based tire dressing. I would say that you can't go wrong with anything Blackfire.
Can I get a ballpark estimate of when the new BLACKFIRE coating may be available?
Jaddie
I will take a wild guess here most likely they will be available around Detail Fest so March 17 again that is my wild guess..
