CarPro essence
Hey guys,
I have had some serious issues with CarPro Essence in the past. Product would be almost impossible to remove from paint after polishing. So I used it twice and never touched it again.
Last week, I had a vehicle where Essence would be perfect.... so I decided to try it a 3rd time. This time around, I was indoor in a climate controled environment as opposed to the first two time working outside in the sun.
I also decided to use it like a sealant, not like a polish. So instead of using an Orange Cutting pad, I used a green light polishing pad. And instead of working it like a polish, I applied it like a sealant...
WOW! What a difference. The product came off super easy, leaving behind insane gloss and covering imperfections. I think I am in love with the product now ;)
I know there is a new version called Essence plus that is out. Would you guy keep using the original version or the revised one? I think the new one doesn't have abrasives in it, so it can't remove damage. But in the end, Essence fills the damage in so I am not sure those abrasives are really needed.
What do you guys think, and have you tried both?
Re: CarPro essence
Well Essence is a primer for coatings and Essence plus is for repairing a coating so they have different intended uses.
Re: CarPro essence
Essence+ is not a revised version of essence. They are two different products for two different things.
As you are aware, Essence is an abrasive polish that leaves SiO2 behind in prep for a coating of Cquartz as the coating will bond to that SiO2 and will merge together. Essence+ was developed to repair a coating as it is a non-abrasive jeweling polish that will fill in minor defects and leave a layer of SiO2. Essence+ is also designed to be hydrophobic compared to Essence.
You can actually use both together. Essence topped with Essence+ where Essence+ will be a sealant.
I think they are both great to have and both work great.
Re: CarPro essence
Key with Essence is to not over work it or heat it up. On a Flex 3401 I use 1 tick above Speed 5 with a light polishing pad. 3-5 passes and then wipe after each section being worked. Works great.
Re: CarPro essence
Ah ok, I did not know they were completelly different, was under the impression they just removed the abrasive from the original formula. Thanks guys!
And yes, light polishing pad worked amazingly well. I used my Bigfoot 21 on speed 3. Did 2 super quick passes to spread the product around and 2 fast passes to ensure perfect coverage then wiped off. I am sure I got basically no correction from it, but I had just compounded the car with D300 which leaves the panel almost ready for LSP so I did not feel it needed extensive polishing.
So I guess I will order more Essence then. I see no need for coating repairs at this point. If it happens I will order some Essence plus
