What do you guys suggest for streak & scratch free cleaning of the dash and in particular, any plastic covering(s) on the gauges (tach, speedometer)??
I was thinking something like lens cleaner (as used for eyeglasses) and proper tissue
Printable View
I use air, then stoners invisible glass with a microfiber.
https://www.autogeek.net/mckees-fast...or-detail.html
Tissue will scratch. Use a MF towel.
the tissue I was going to use is Kimwipe which is the standard for cleaning delicate optics. Or Zeiss lens cleaner for eyeglasses.
Point taken on using a MF.
Yes sir. The plastics used on the gauge lens are super soft. They will scratch just looking at them.
Another new product you can look into...
https://www.autogeek.net/ultima-screen-protect-4oz.html
What ever you use, do not, I repeat do not wipe the gauge lens with a dry cloth.
The problem is only partly the cloth - its mostly the grit that's all over the plastic. I've had good luck using a swifter sister (the poofy blue or yellow thing, not the white cloth) first. I use a meguairs plastic detailer on cotton or MF to get it super clear as soon as it's grit free
^^ hahahahahaha, good one. (Bet he doesn't get it.)
