Foam Cannon and Pressure washer, Which ones do you use?
Looking to expand my business to mobile detailing. Trying to figure out a good electric pressure washer ( possibly gas ) to sustain a good amount of foam from a MTM PF22 or the MTM Low pressure cannon. Let me know what you're guy's experience is when it comes to electric pressure washers and the foam cannons. Welcome any video examples also.
Re: Foam Cannon and Pressure washer, Which ones do you use?
Honda is all I use buy once that's it.Sorry couldn't hello.
https://instagram.com/p/BWQZLiaDyEn/
Here’s my set up. MTM PF22 with a SunJoe SPX-4001 2030PSI 1.76GPM
Been absolutely awesome using it every week.
I have a 1600psi electric Greenworks power washer and MTM foam cannon. Works great. I also replaced the hose/gun that came in the unit with MTM ones. Short gun, easier to use trigger.
SunJoe SPX3000 and 20.00 foam cannon bought off of Amazon
Kranzle K1622 PW
Mosmatic Swiveling Spray Gun and 20" SS bent wand
MTM PF22 Foam Cannon
Quote:
Originally Posted by
lane5515
Kranzle K1622 PW
This guy likes Matt Mormon with Obsessed Garage. As do I. [emoji122][emoji108][emoji106]
I personally use the kranzle 1122 for my stationary business I just really don't want to be hauling around a thousand dollar machine! I've been contemplating with the sun Joe and its a decent price point and will do what I need it to for mobile operations.
Anyone have both of the pf22 and the low pressure model? And opinions on both?
I have a 2600psi Troybilt gas unit and a cheap Amazon foam gun
Whooaa does that setup make some foam. It's quite impressive.
I'm sure the more expensive units at AG are better...
SunJoe 3001, MTM PF22 cannon , MTM SG35 gun, Gyeon Foam at 1:10. Generally never turn cannon all the way +; prefer a wetter foam to dryer shaving cream foam.
If only SunJoe didn't use those non-standard fittings...14mm vs 15mm I believe.https://uploads.tapatalk-cdn.com/201...228c8916a0.jpg
Sent from my SM-G930T using Tapatalk
