[Help] Cutting speed option and pads for Flex 7 150
Hello guys,
I just bought the Flex 7 15 150 and I tried to use it for cutting step after wet sanding step with speed 5 and LC Orange pad 6 inch with FG400 compound but it leaves many swirl marks on the paint surface. I also tried the 5 inch microfiber pad but stiml remain the same 😔
The arm speed and body movement are slow.
When using rotary machine, I can remove all swirls but with the Flex, Im stuck on it. Am I lacking on some technique for this XFE7? So now I really need some help from anyone who tried the XFE7.
Any help is appreciated 😊
Thank you all!
Re: [Help] Cutting speed option and pads for Flex 7 150
Quote:
Originally Posted by
KeryNg
Hello guys,
Thank you all!
anytime you use a compound you are going to see marring and with a microfiber pad as well. You will need to go over it with a polishing pad and a polish. Something like M205 or a menzerna polish
When I use rotary polisher, swirl marks fade alot and I switch to polishing step all marks will go away. But with the XFE, many marks still there even after the polishing step with white LC pad & medium cut compound.
Is speed 5 is good enough for the cutting? About the arm speed should I go from very slow/slow or medium?
I want to use XFE for all steps using all step pads n compound instead of using rotary polisher then xfe for polishing step
Am I doing something wrong ?
