My new Pressure Washer!! Pretty Stoked!!
I work at a motorcycle shop part time (www.schietsmotorsports.com) and figured id pick up one of the best pressure washers money can buy since i get it at a hell of a cost.
Yamaha PW3028 3000PSI
https://www.yamahamotorsports.com/pr.../models/pw3028
CAT pump, all brass fittings, exactly what ive always wanted. The end it comes with will rotate to whatever spray pattern you want. Its very nice and you can feel the quality in this unit. Cant wait to get my Torq foam cannon hooked onto the end of it and start spraying!!!
https://farm5.staticflickr.com/4307/...a4e06263_c.jpgIMG_2374 by ICEMAN TMCF, on Flickr
https://farm5.staticflickr.com/4302/...1cdb57ac_c.jpgIMG_2381 by ICEMAN TMCF, on Flickr
Re: My new Pressure Washer!! Pretty Stoked!!
Congrats on the purchase. I just watched a video and it looks really nice. The only problem I see is.....for a car, would be that it's gas and not electric. With the gas, you cannot simply put down the wand and wash individual wheels without turning it off and starting it up multiple times. Keep us posted.
Quote:
Originally Posted by
WaxMaster1
Joe@NextLevelDetail
Nice, 2.8 GPM :O
With how i have my routine set up, it shouldnt be an issue. Its a yamaha so even if i had to shut it off multiple times, i am not worried about the motor one bit. You're supposed to shut it off every time to remove something from the 1/4" quick connect (per the manual). so im supposed to shut it off every time i take off the foam cannon to put on the standard spray end.
Detailing isnt the only thing i bought it for. i bought it for many other uses as well!
One thing i really like is how it has the 800PSI nozzle on the rotating tip.
That rotating nozzle is cool. That spray wand looks like its built to serious use. 2.8 gallons per minute isn't far off my regular hose at full volume.
LEDetailing
Ya i cant wait to get at it!!!! My little 2000 Watt Yamaha Generator has been a beast for the past 3 years for what ive put it through. Honda or Yamaha for me, when it comes to this type of equipment!!
Yamaha is giving an extra year warranty with these purchases so I have 4 years of a full warranty so thats nice. With 3.9% financing i didnt have to drop the entire amount right away,. i threw it on the card and put some down. This way i will only pay 10-20 bucks over the little bit of time til i pay it off. Figured why not. That way i drop around $700 all at once. lol.
well i finally used it and DAMN is it nice. The 800PSI nozzle is great when rinsing. Its nice to be able to quickly switch from a powerful spray to a lighter spray in a second. I need to adjust the foam ratio in the Torq Foam Cannon but it still worked great. Left it run the entire time except when i was done foaming i turned it off to remove the foam cannon to put the rotating nozzle on. It runs quiet when the pump isnt being used.
WaxMaster1
I let it run the entire time. I have no issues doing it. Like i mention in a previous post, its a Yamaha, the motor is gonna last. Its built to run. Ive used it a few dozen times at least already on house and car projects and its amazing to have. Using it with the Torq foam cannon is awesome.
As i mention above as well, the 800psi spray nozzle is nice to have for delicate areas where you dont want a full spray nozzle. Yah you have to shut the machine off when you switch from the foam cannon back to the factory rotating spray nozzle, but thats it. Then you let it run til you're done washing.
This is my Yamaha set!
https://farm5.staticflickr.com/4445/...6d1d6c8a_h.jpgMy Yamahas by ICEMAN TMCF, on Flickr
I love my pressure washer
