Will Pinnacle Paint Cleansing Lotion Remove Wolfgang Deep Gloss Paint Sealant?
I know that Pinnacle Paintwork Cleansing Lotion is intended as an additional step in the washing/cleaning process prior to waxing. Will the microabrasives in the Cleansing Lotion remove previously applied Wolfgang Deep Gloss Paint Sealant? Thanks!
Re: Will Pinnacle Paint Cleansing Lotion Remove Wolfgang Deep Gloss Paint Sealant?
I'd say yes.
The Pinnacle Paintwork Cleansing Lotion isn't abrasive but the simply act of applying a product brings with it micro-abrasive from the applicator and the process.
Kind of like washing a car. When you wash a car you micro-abrade the surface and this is way waxes and sealants wear-off. It's actually kind of supposed to work like that as waxes and sealants are
Sacrificial Barriers
I have an article on this somewhere?
Quote:
Originally Posted by
Mike Phillips
I'd say yes.
Good info here.......
https://www.autogeekonline.net/forum...t-sealant.html
Mike Phillips
I'd say yes.
Thanks, Mike! I was just wondering if I should be using Paintwork Cleansing Lotion after washing/before waxing if is not yet time to reapply DGPS, and the answer is "no". I assumed that was probably the case; just wanted to be certain.
Mike Phillips
You have an article on EVERYTHING!!! It amazes me how you can retrieve something you wrote years ago. Hats off to your (obvious) meticulous record keeping!
Mike Honcho
Sent from my iPhone using
Autogeekonline mobile app
Mike would have made a great librarian.:dblthumb2:
