Video: How to take care of your automotive plastic trim - Gyeon Trim Care
Jeff McEachran stopped by and together with Yancy we shot a new video showcasing the GYEON Q2 Trim.
https://www.youtube.com/watch?v=thOtCRu4tOo
Quartz-based protection that lasts!
GYEON Car Care offers a full range of quartz-based vehicle coatings, along with all of the tools and products needed to maintain the treated vehicle’s finish.
Not only are the formulas offered the most technologically advanced, they’re also designed to be easy to use at any skill level, appealing to detailing hobbyists and professionals alike. GYEON forgoes fancy coloring and scents, providing genuine, long-lasting results that will turn heads.
GYEON is gaining a reputation worldwide as a source for the best quality car coatings. Each GYEON product is carefully crafted to provide the best results, and the best value. GYEON provides innovative solutions for high-quality surface protection that lasts longer than traditional options. That means each application yields months of protection, as opposed to mere weeks!
Protect plastic and trim for up to 6 months!
GYEON Q2 Trim is an easy to apply, long lasting quartz-based trim protectant that shields against UV rays and environmental contaminants. This unique formula bonds to plastics without causing damage or discoloration. GYEON Q2 Trim actually helps maintain the deep black of plastic trim and the crystal clear quality of clear plastics.
You may have discovered the benefits of quartz-based coatings for paint. They protect like no other and allow water to bead up and roll off creating a self-cleaning effect. GYEON Q2 Trim brings all of those properties to your trim! Nothing looks worse on a freshly detailed vehicle than gray trim that should be black! After one easy application of GYEON Q2 Trim you’ll have about 6 months of protection for all of your plastic and trim work.
GYEON Q2 Trim is SiO2-based and bonds with plastics to protect them from degradation. Once plastic starts to turn, it can be difficult to revive it and keep it looking good. As soon as you get a new vehicle, coat it with GYEON Q2 Trim to ensure that plastic and trim continues to look great mile after mile. One coat of GYEON Q2 Trim repels water and environmental contaminants to keep your vehicle looking great!
Directions for Application:
Always work on a clean, dry surface out of direct sunlight.
Prepare the surface using GYEON Prep to remove any residue to ensure proper bonding.
Shake GYEON Q2 Trim well.
Using the included applicator, spread a thick, even layer of GYEON Q2 Trim over the surface in a crisscross pattern.
After the section is coated, wait 2-5 minutes and then wipe off any excess using a microfiber towel.
On Autogeek.com
GYEON Q2 Trim - 30 ml
