As the title suggests, I am looking for the easiest-to-use ceramic coating. Least prep, application and finishing requirements.
thanks,
Jim
Printable View
thanks,
Jim
From what I've read so far, McKee's 37 Paint coating is the easiest to apply & remove. I've also used it and it IS very easy.
I haven't tried it but I want to. Looks the easiest to me.
SONAX CC36 Ceramic Coating
Prep work is pretty consistent across the board with nano coatings. The real differentiation comes with the actual application process. Some coatings require a lot of attention to wipe off times, type of towels used, ambient conditions (temp and humidity), etc etc etc.
These are my favorite coatings when "ease of use" is an important factor....
22ple - All are VERY easy to use. HPC and VX3 are my favorite (in that order)
GTechniq - CSL is great. As long as you know how to use it, it is very easy. Wipe on, wipe off. Let it sit and you'll have issues. (This is my all around favorite coating at the moment)
Optimum - Gloss Coat is a breeze. Apply to panel, let it flash, gently remove high spots, move on to next panel.
McKee's, Pinnacle and 22PLe are all fairly easy to apply.
Mckee'37 is beyond easy. However, any and all coatings really need the same prep, as in making sure the finish is free of defects (compounded and polished) and then the surface cleaned before application.
If the coating is applied over a imperfect surface, the imperfections are being "coated" in as well as it will not look as good and potentially not last as long.
The spray on coatings like McKee's and PBL are by far the easiest to apply. However, I don't think they are as durable as the others.
In terms of the conventional wipe-on coatings, I have to say that Wolfgang Uber is the easiest to apply. I've applied this when it is 90 degrees in my garage and when it was 50 degrees in my garage. It goes on extremely easily and buffs off with such little effort.
I agree with Zach about 22PLE.
There are quite a few that look fantastic but require a bit more attention to apply and buff.
Blackfire Crystal Coat.........Im the MAN
Pinnacle Black Label Diamond Paint Coating v2. It's super easy to work with but you will need to spend some time prepping the paint surface. Pinnacle Black Label Diamond Paint Coating
http://www.autogeekonline.net/galler...ating_01A_.jpg
