What do you guys think of these Sun Joe power washers? Great PSI and GPM!
https://www.amazon.com/Joe-SPX3001-E.../dp/B00LX8Z03K
Will the Auto Geek foam cannon work with this?
Printable View
I have the SPX3000, it works great with a foam canon. I get a lot of thick foam.
The only issue is it comes with a 25 ft. hose and I had to constantly move it to get around bigger vehicles. I bought the 25' extension hose and the pressure did drop slightly. Not sure exactly but I did notice its not as strong and the foam is slightly less. Still not a huge deal though.
The AS390SS seems very nice as well..it is the highest rated over on pressurewashersdirect.com
SUNJOE now has a foam cannon, now all I need is a rubber upgrade rubber (flexible) hose and shorter gun >>>>>>>>>>>>Sun Joe 34 oz. Foamer Cannon for SPX Series Pressure Washers-SPX-FC34 - The Home Depot
https://www.youtube.com/watch?v=HugVNe7XnMg video sunjoe foam cannon
^ or you can buy a foam cannon from AG...
Car Wash Products
Karcher K4 or K5 have better internals.
MTM makes a low pressure specific foam cannon for electric pressure washers. Technically all it has is a smaller orifice pre-installed. Either way you WILL notice a difference between a standard foam cannon and one with a 1mm/3.0 orifice
https://www.mtmhydroparts.com/collec...ayonet-14-0349
or you can buy the 1mm/3.0 orifice nozzle for your current cannon (like i did) costs $7
https://www.mtmhydroparts.com/collec...-cannon-nozzle
I have one and love it. Swap out the cheap plastic fittings, and you're set. For the record, I have a cheapy Amazon 20.00 foam cannon, and it works great
Just used mine today for the first time - absolutely love it!
