Pictures: 2016 Challenger Scatpack Shaker & 2016 Dodge Hellcat - Black Label Diamond Paint Coating
Wow! Huge turn out tonight!
We machine polished and applied Pinnacle Black Label Diamond Paint coating to the 2016 Challenger Scatpack Shaker and the Sublime Hellcat is sporting Wolfgang Deep Gloss Paint Sealant 3.0
http://www.autogeekonline.net/galler...hp?file=107225
http://www.autogeekonline.net/galler...hp?file=107226
Time to shut down Autogeek's Show Car Garage for the night - Thank you to everyone that attended tonight.
Thank you Ken and Frank for trusting Autogeek with your wicked bad Mopars!
Re: Pictures: 2016 Challenger Scatpack Shaker & 2016 Dodge Hellcat - Black Label Diamond Paint Coating
Sweet cars! Look awesome too! Wish you would have one of these in DFW...*hint hint wink wink nudge nudge*
Outstanding! Nice work gang!
AutoGeek Show Car Garage, Where all the action is at!
Holograms in paint
Ken recently had the driver's front fender repainted due to a foam gun accident. Here's the two Mopars as they pulled into Autogeek's Corporate Headquarters.
http://www.autogeekonline.net/galler...hp?file=107281
Here's the front driver's fender...
http://www.autogeekonline.net/galler...hp?file=107282
Holograms in the paint
Here you can see where after painting and then buffing the repaired area the body shop left holograms in the finish.
http://www.autogeekonline.net/galler...hp?file=107283
http://www.autogeekonline.net/galler...hp?file=107284
http://www.autogeekonline.net/galler...hp?file=107285
http://www.autogeekonline.net/galler...hp?file=107286
No problemo...
While Ken's car is here we'll remove the holograms.
Just to note...
Recently I wrote a full-blown, in-depth article on how to use a foam gun and covered EVERY base to help others get the best performance out of their foam gun and also to avoid any accidents. Here's the link to the article,
How to use a foam gun by Mike Phillips
In post #4 I included this,
If the female coupling is NOT locked onto the male coupling, when the sprayer is hooked up to water and you press the sprayer the force of the water will push the Foam Metering Head and the quart of soapy water solution off the end of the sprayer and onto your car!
So pay attention!
http://www.autogeekonline.net/galler...hp?file=106676
So learn from Ken's experience and make sure the foam gun sprayer is correctly attached to the foam gun mixing head before you use the foam gun.
Ken had thoroughly washed and dried his R/T Scatpack Shaker before driving to Autogeek and he only lives a short distance away. We inspected the paint using the baggie test and found it to be contaminated so first thing as to use Pinnacle Ultra Poly Detailing Clay to remove the contaminants.
http://www.autogeekonline.net/galler...hp?file=107287
http://www.autogeekonline.net/galler...hp?file=107288
http://www.autogeekonline.net/galler...hp?file=107289
http://www.autogeekonline.net/galler...hp?file=107290
http://www.autogeekonline.net/galler...hp?file=107291
Machine polishing
NEW PRODUCT
New updated formula - Pinnacle Advanced Finishing Polish
Besides the hologram scratches from the body shop the rest of the paint on Ken's car looked pretty good but my rule for car detailing is if I'm going do any mechanical decontamination, in this case the class used detailing clay to clay the paint, then I'm going to do at least ONE MACHINE POLISHING STEP to ensure a pristine, better than new finish.
Nick gave me 6 bottles of the newly upgraded and improved Pinnacle Advanced Finishing Polish to use for this project. Most of the people you'll see in the pictures below were brand new to machine polishing so they wouldn't know a bad polish from a good polish. They simply don't have the experience to judge good from bad. What they did to however is polish the paint on this car without a single issue. And they turned out PROFESSIONAL quality results their very first time machine polishing.
I'm here to tell you - when it comes to polishing paint the MOST IMPORTANT factor is the abrasive technology. If the abrasive technology is junk then you're going to get junk results and you're going to struggle and waste time. Pinnacle uses the bet in abrasive technology and this is why I have the confidence to use it on cool cars like this and also switch Wayne Carini's shop over to Pinnacle compounds and polishes for the million dollar cars he works on.
For this class we had a very nice young lady named Grace join us and like many of the guys, this was her first time machine polishing paint.
http://www.autogeekonline.net/galler...hp?file=107292
http://www.autogeekonline.net/galler...hp?file=107293
http://www.autogeekonline.net/galler...hp?file=107294
Here's Robert DiTerrlizzi removing the holograms out of the driver's front fender
http://www.autogeekonline.net/galler...hp?file=107296
Eric, long time forum member all the way down from New York joined us tonight. Here he is using the RUPES IBrid Nano orbital polisher
http://www.autogeekonline.net/galler...hp?file=107297
http://www.autogeekonline.net/galler...hp?file=107298
http://www.autogeekonline.net/galler...hp?file=107299
This is the third time George has join us for our Thursday night detailing classs....
http://www.autogeekonline.net/galler...hp?file=107300
http://www.autogeekonline.net/galler...hp?file=107301
That's Ken the owner on the left working on his roof. After tonight Ken will have the confidence to machine polish the paint on his car by himself...
http://www.autogeekonline.net/galler...hp?file=107302
http://www.autogeekonline.net/galler...hp?file=107303
http://www.autogeekonline.net/galler...hp?file=107304
Applying a Ceramic Paint Coating
After prepping the paint with Pinnacle Black Label Surface Cleansing Lotion to remove any residual polishing oils off the paint after polishing it was time to apply the Pinnacle Black Label Diamond Paint Coating v2
How to apply a ceramic paint coating
Here's the class working as a team to apply the coating to the car. The process is simple,
Step 1: If you're by yourself then you apply the coating to a single panel at a time.
Step 2: Wait one minute and then inspect the panel and continue spreading out any high spots. Look at the panel at an angle and use available overhead light to find high spots.
Step 3: Wait one more minute and then wipe the panel with a clean, soft microfiber towel. At this point wipe off any high spots and give the entire a panel as soft wipe.
Step 4: Repeat to the next panel.
http://www.autogeekonline.net/galler...hp?file=107305
http://www.autogeekonline.net/galler...hp?file=107306
http://www.autogeekonline.net/galler...hp?file=107307
http://www.autogeekonline.net/galler...hp?file=107308
http://www.autogeekonline.net/galler...hp?file=107309
Gentle buff
After applying the coating and spreading it over the surface next you wipe each panel using a clean, soft microfiber towel to remove any high spots or excess product.
http://www.autogeekonline.net/galler...hp?file=107310
http://www.autogeekonline.net/galler...hp?file=107311
http://www.autogeekonline.net/galler...hp?file=107312
http://www.autogeekonline.net/galler...hp?file=107313
http://www.autogeekonline.net/galler...hp?file=107314
http://www.autogeekonline.net/galler...hp?file=107315
http://www.autogeekonline.net/galler...hp?file=107316
Very nice!!!!!!! I can't wait to try out my black label coatings!!
How did you apply the cleansing lotion? By hand or machine?
