Pictures: 1972 Corvette Stingray - Original Single Stage Paint - Autogeek Extreme Makeover!
1972 Corvette Stingray with the Original Single Stage Paint
http://www.autogeekonline.net/galler...hp?file=106970
:buffing:
Printable View
:buffing:
Been very busy with behind the scenes work for Waxstock and my detailing class in London but have not forgot about sharing how we restored the paint on this original paint 1972 Corvette.
Here's the before pictures I took last Thursday night. Besides the swirls the pait was simply FLAT or MATTE in other words dull with zero gloss and shine.
http://www.autogeekonline.net/galler...hp?file=107138
http://www.autogeekonline.net/galler...hp?file=107139
http://www.autogeekonline.net/galler...hp?file=107140
http://www.autogeekonline.net/galler...hp?file=107141
http://www.autogeekonline.net/galler...hp?file=107142
http://www.autogeekonline.net/galler...hp?file=107143
http://www.autogeekonline.net/galler...hp?file=107144
http://www.autogeekonline.net/galler...hp?file=107145
More pics to come....
love the '72 corvette....can not wait to see the pics
How to use a Wire Wheel Brush to clean Chrome Wire Wheels
http://www.autogeekonline.net/galler...hp?file=107212
There's a something about chrome wire wheels that when they're clean and the tires are properly dress they add so much class to any vehicle. But when chrome wire wheels are dirty they're an eyesore that takes away from the beauty of the car.
The issue is with all those wire spokes it can take forever to remove all the brake dust and road grime and restore the chrome shine and brilliance to the wheel. That's where you need and want an Wire Wheel Brush.
A wire wheel brush has thousands of bristles along the shaft so when you run the brush in-and-out of the spokes every portion of the spoke gets cleaned. The brush head is tapered giving creating a cone shape making it easy to quickly slip the head of the brush into each new set of wire spokes as you methodically work your way around the wheel.
http://www.autogeekonline.net/galler...hp?file=107213
http://www.autogeekonline.net/galler...hp?file=107215
The bristles themselves are chemical resistant and won't scratch chrome surfaces.
http://www.autogeekonline.net/galler...hp?file=107214
How to clean spoke wheels
While having a well designed brush makes cleaning wire spoke wheels easier and more efficient you still have to get down and do the work part of running the brush in-and-out of each set of spokes plus both sides of where the 2 sets of spokes intersect.
To complement the wire wheel brush you want to use a good wheel cleaner that will dissolve and remove any built-up brake dust and road grime.
Step 1: Now this is key, pick a STARTING POINT that you can remember such as a word on the tire or even the set of spokes next to the air valve. Then begin methodically running the brush in-and-out of the spokes.
Step 2: Run the brush around the wheel until you end up at the starting point.
Step 3: Agitate the outer lip of the rim with a quality wheel brush like the Wheel Woolies Black Boar's Hair Wheel Brush and then rinse well with water.
Step 4: After washing and rinsing the wire spokes next scrub and rinse the tires.
Step 5: After scrubbing the tire clean next rinse the tire with a strong blast of water.
Technique Tip
By starting with the wheels first and then moving to the tire sidewall when you go to rinse the sidewall you'll have another opportunity to rinse the wheel and flush out any wheel cleaning residues, brake dust and road grime that pooled via gravity in lower areas of the wheel while you were cleaning the tire.
Clean wheels first
The chrome spoke wheels are dull with brake dust and road grime and the tires are turning brown and aged looking...
http://www.autogeekonline.net/galler...hp?file=107192
http://www.autogeekonline.net/galler...hp?file=107193
Here's my friend Frank cleaning the chrome wire spokes on the wire wheels on this classic 1972 Corvette. First Frank sprays McKee's 37 Foaming Wheel Cleaner Gel to the spokes of the wheel.
http://www.autogeekonline.net/galler...hp?file=107194
Next Frank pics a starting point and then methodically runs the wire wheel brush in-and-out of each set of wire spokes.
http://www.autogeekonline.net/galler...hp?file=107195
http://www.autogeekonline.net/galler...hp?file=107196
Clean tires second
After all 4 sets of wire wheels are clean next up Ken, the owner of the Corvette scrubs the tires. You can scrub the tires by hand with a tire cleaning brush or as an option, if you own a Porter Cable dual action polisher, attach a Cyclo green carpet and upholstery brush onto the Porter Cable polisher and turn your paint polisher into a machine tire scrubber.
http://www.autogeekonline.net/galler...hp?file=107198
http://www.autogeekonline.net/galler...hp?file=107199
John Michael, our guest from Italy gives machine scrubbing a try...
http://www.autogeekonline.net/galler...hp?file=107200
http://www.autogeekonline.net/galler...hp?file=107201
Dress Tires last
After the wheels and tires are washed, dried and clean, nest apply a tire dressing to seal the tires and complete the finished look. For this Frank is using McKee's Gloss Tire Gel and a foam tire swipe.
http://www.autogeekonline.net/galler...hp?file=107202
http://www.autogeekonline.net/galler...hp?file=107203
http://www.autogeekonline.net/galler...hp?file=107204
http://www.autogeekonline.net/galler...hp?file=107205
End results...
http://www.autogeekonline.net/galler...hp?file=107206
http://www.autogeekonline.net/galler...hp?file=107207
http://www.autogeekonline.net/galler...hp?file=107208
http://www.autogeekonline.net/galler...hp?file=107209
http://www.autogeekonline.net/galler...hp?file=107210
Looks like Ken is pretty happy with his sparkling clean wire wheels on his all original 1972 Corvette Stingray!
http://www.autogeekonline.net/galler...hp?file=107211
On Autogeek.com
16 Inch Wire Wheel Brush
McKee's 37 Tire & Rubber Rejuvenator
Porter Cable 7424XP Dual Action Polisher
2 Pack Cyclo Polisher Aqua Soft Carpet Brush
Flex Foam Tire Dressing Applicators - 3 Pack
beautiful !!!
Looking good!
lovin' the '72 corvette so muchhhh. <3
***Update***
A month or so ago Kent contacted me and let me know some lady in a Hyundai t-boned his all original, family-purchased-new Corvette.
Thankfully you can get a Hyundai in Anytown, USA.
:dunno:
Hey I just noticed you gave a little love to my favorite wheel brush at the top of this thread...
https://uploads.tapatalk-cdn.com/201...e48d3d6be8.jpg
This brush is like the unsung hero of wheel brushes.. It gets treated like the red headed stepchild by most people because they fear it'll scratch their wheels.
1st time I've seen it get featured in a write up by anyone besides myself:)
Everyone loves the Wheel Woolie, but this brush is a true underdog, so I like to call it the Moolie.
https://uploads.tapatalk-cdn.com/201...b24f3e6681.jpg
Mini Moolie. Lol.
https://uploads.tapatalk-cdn.com/201...2d995a3bb2.jpg
