I'm having a problem with the sticky stuff on the back of a sticker after removing it from a car what will take it off easy?Attachment 50173
Printable View
Maybe Goo Gone or Mineral Spirits or Acetone / Nail Polish. Start with Goo Gone if you have it.
You need a solvent. Tar remover, mineral spirits, lacquer thinner if it's factory paint, you can try IPA but that may not work. Or Goo Gone or similar as noted.
Goo Gone works very well. You might need to let it sit for a minute and then lightly rub it with your fingers. Windex sometimes works, too.
Try rapid remover. Not a car product per say but works wonders for tar grease carpets and sticky residue!
Sent from my SGH-I747M using Tapatalk
Another vote for Goo Gone. If that didn't work, Stoner's Tarminator should work well too.
Stoner Tarminator removes bug residue, tar, tree sap, gum and more from automotive surfaces! bug & tar remover, auto spot cleaner, car bug & tar
Goo gone or WD-40 spray. I use both often.
If nothing else since it's an emergency, try compounding it after you've exhausted your fingernails.
