Since Amazing Roll-Off is a multi-purpose cleaner I was wondering if anyone has experience and/or knows if it would be safe to use Amazing Roll-Off on a rubber roof on a MH?
Thanks
Printable View
Thanks
Yes but the key is you have to have someone on the ground with a hose keeping the side wet.so if your working on the front they must follow you with a hose to rinse off the side,cause etching or staining may occur especially on graphics.Take some bleach up there as well.
Works great on tires and that's rubber. Always do a test spot first.
Good advise by GSKR.
I had the same thought a few years ago but did not want to risk it as it could be a 7-12K dollar mistake. Instead I use DG 901 and a sponge mop or Boars hair brush and rinse the sides from the roof as I move front to back.
Dave
