Re: Utility Cart Lighting?
I have an 110v. PAR 38 LED bulb in one of those squeeze clamp fixtures that I clamp on one of my cart shelves. I use it as side panel lighting, but it's close at hand and easy to grab for closer inspection when needed.
Bill
That's a great idea BillyJack.
1 Attachment(s)
You mean something like this. If you want for info message me. These are 6k lumen LED light bars that pull less than 1 amp each
Quote:
Originally Posted by
BillyJack
Bill
Nice idea. Is this powerful enough though? I guess 14W seems low. What color temp did you go with?
Mine are PAR 20 (sorry for the error in my first post) 500 lumens, 5000k temp. I suppose something brighter will work, but these are compact in size,
quite portable and I'm very happy with performance.
Bill
BillyJack
Bill
Gotcha. I found a clamp lamp that holds up to 200 watts. I think I am going to try and find the highest lumen LED daylight bulb I can find and try that set up.
Hello. That is a very cool set up. Wanted to know if that is a reg t8 tube or integrated tube? If it is a standard t8 tube what do u have connected to the ends so that you are able to just plug them in directly to outlet? Thanks
refreshauto
I have a craftsman resin two shelf cart with a snap on led worklight on each shelf. Works great! Got the lights from Costco, but I’ve seen them on amazon and eBay.
