Re: interesting challenge...
I don't think you will be able to sand that.Take it off then sand it.
I already removed the PPF just going to sand the edge that's left because the paint is from almost level to 3 mils thicker where it didn't have the PPF
•An "interesting challenge" is
quite the understatement!
-It's definitely going to be difficult
to blend-in ~a 3 mil butte, to match
the elevation of an almost level steppe.
-Your wet-sanding the edge process
is a good approach, IMO.
Dave
Please keep us posted on this
Be careful when sanding and polishing the side that was covered you could break through. I would use a paint gauge for removal of material. Good luck
Quote:
Originally Posted by
detailsbydennis
Thanks I just did an M 3 that I pulled the PPF. It actually had a lot more. If this car is like the other black Infinitys I've done the paint is rock hard, I'm always as careful as I can be. I would feel a lot better about this if the respray was single stage. I may end up hitting the color coat on that side. The customer is aware of the issue. I told them I would do the best I could.
5 Attachment(s)
Feed back please:nomore::nomore:I should have taken some before pics after it was washed the car. I have no idea what that white stuff is on the front of the hood. It wasn't adhesive though. I tried everything including WD 40 and nothing took it off. The line actually looks worse in the picture than it does in person. Considering what I was working with it actually came pretty decent.
Attachment 60114
Attachment 60115
Attachment 60117u
Reflection shot
Attachment 60118
Looks great
