thank you
Printable View
thank you
Rupes iBrid has all you need, but very not cheap
I stripped all the wood out of my AMG then polished them with a 3" GG. Same steps as the car paint. The clear is soft. When I finished I applied 22ple coating to the clear. I also have applied several other brands of coatings. The coatings will keep the gloss and minimize the scratch level. Wont eliminate the scratches, however will help against a microfiber cloth being rubbed to hard on the clear and micro-scratches occurring. Easy to take the center console apart and then polish outside of the vehicle. DASH and doors you can either 3" painter tape and polish directly on the car or hand polish as best as possible. Either way, coatings are wonderful for interior clear coated wood trim.
Agree the Nano iBrid was made for this.
But remember plastic does not dissapate heat the way metal does so easy on the speeds.
Hand application with a microfiber cloth is suprisingly harsh way to apply polish.
You can apply way more force with your hand on the towel than you can with a foam pad on a polisher.
I would use a mild poish designed for plastic and a medium pad (Plast-X and white pads for me).
