Re: Rinseless wash method?
Most here use similar method. I don’t use the “damp” towel.
First i pretreat the panel with sprayed on rinseless solution. Let dwell couple minutes then use rinsless towel out of bucket, wrung out so it is barely dripping.
One pass per side. Use all 8 side goes into clean bucket. I then dry per panel using a PFM and sometimes a drying aid. I feel the middle wipe is not needed and save that effort to apply a sealant or quick detailer after.
Also when wiping i roll the towel across the panel. Picture holding end of MF between thumb and for finger.
As I drag Rinseless towel I start with palm facing paint and slowly roll had up as I make my pass. This pulls dirty edge up and off paint.
If you wanna see a video of technique loook up Ammo NYC Frothe video.
I would add this technique and pretreat to your routine if not already doing.
To each his own, my procedure is a lot simpler. I put 1.5 oz of ech20 in a bucket of water, add five microfiber towels, pull em from the bucket, and do two panels, and discard for later washer, then dry with a waffle weave… Been doing it this way for about 10 years, never fails me. No scratch, car looks great.
I understand that everyone has their own methods and techniques and there is "more than one way to skin a cat" but here is mine...
In my opinion, pretreating panels, multiple towels and/or dual buckets are not necessary for a safe, effective wash. KEEP IT SIMPLE. Don't overthink or overcomplicate the process as many do.
One wash mitt, one grit guard and one bucket with 3 gallons of water and rinseless solution is all you need as long as you follow some basic technique rules.
1. Do one panel at a time. It's easier this way and you don't have to worry about the solution drying on the paint if you cover wider areas.
2. Dedicate one side of the wash mitt for the initial pass. This picks up 95% of all surface dirt and applies the first layer of solution to the surface. Use LIGHT pressure (just enough to keep it flat and gliding). Cover the panel in one continuous motion (as if you were mowing the lawn) without ever allowing your wash mitt to touch the surfaces that you already wiped. The point of this first pass is to pick up (transfer) *most* of the surface dirt from the paint into your wash mitt in the least aggressive manner. Remember, trust the rinseless wash solution (assuming your using a good one).
3. Flip your wash mitt to the other side. This is a fresh clean side. Wipe down the panel again in the same continuous motion using light pressure again. This pass will remove the remaining dirt left (if any). There is also no concern at this point with moving your wash mitt over areas you've already wiped because there are no contaminants left on the paint to worry about scratching. It's basically clean.
4. Dunk the dirty side of the wash mitt (the side used for your initial pass) face down to the bottom of the bucket. With your hand, keep it pressed against the grit guard and slightly twist your wrist in a motion that grinds the mitt on the grit guard. This dislodges all the dirt from the wash mitt directly towards the bottom of the bucket and it keeps it trapped. The point of this is to immediately force the dirt to the bottom of the bucket rather than dislodging dirt at the top of the water, which risks these particles (as they are floating around) to adhere back onto the wash mitt as you dunk and lift it from the solution.
5. Use your favorite drying towel to dry the surface.
6. Move to next panel and repeat steps 2-5.
I pre-treat using a Marolex sprayer. I then put a few mf towels in the rw solution bucket and clean/wipe dry. I've used the BRB. It works but not my favorite. I've used ech20 and ONR. Like both a lot.
Back in the day 50s and 60s a common rinseless wash was a cup of KEROSENE in a bucket of water.Wash with a towel or sponge and wipe dry with a towel .It would prevent rust comming from metal clips that hold mouldings on. It would keep road film from collecting on paint, and it would put a little shine on paint. Kerosene is not that oily like diesel fuel . Mixed with water it would make a white solution.
I still use the original "Gary Dean Method" that I saw in a video nine years ago:
Pre-spray with rinseless solution
Multiple towels soaking in a bucket of rinseless solution
Damp towel to "dry" the panels
Dry towel for final buff, although it's been so hot lately that the solution practically evaporates after drying with the damp towel
Question for the OP: What's the purpose of a grit guard if you're not reintroducing the used towels back into the bucket? Just curious because I've never thought of using one for this.
I spray the car with 1oz of N-914 diluted in 1.5L of water. Then use 2 buckets with grit guard, one with 2oz of N-914 in it, the other is just water. I use the Big Red Sponge. Before going in for more rinseless solution, I dunk it in the water bucket and agitate against the grit guard/washboard just to try and remove anything it might have caught, then it goes into the bucket with the solution and is ready to use again. Finally, I dry the panels I cleaned.
Quote:
Originally Posted by
Kappy
If you are using new water/solution every wash, there really isnt a need for the Grit Guard. In my case the solution is used for multiple washes and im actually storing the microfibers in the solution while not in use. The Grit Guard is just in case the microfibers have anything extra left on them after the wash and in the hopes that it helps. Also, ive seen the solution go "bad" after a couple months and there were some extra little bits at the bottom of the bucket, so i started using the GG.
Kinalyx
My thinking exactly.
My RW buckets always have Grit Guards to keep the mitts/towels from lying on the bottom of the bucket.
Theoretically, there shouldn't be any debris. But I don't live on theory. :D
