2014 BMW 320i Full Pinnacle Black Label Coating
Good evening,
Today I'm going to share a recent work on a brand new 2014 Black BMW 320i in form of a 'picture follow-up'.
The car ran only ~280km, but came with DISO (Dealer Installed Swirl Option), RIDS and water spots that made it looks much older.
Client called asking for something to protect her finish. Knowing it was a brand new car, I've offered my PBL full coating service and I've thought that would be 'as easy as' cleaning and coating…
I've scheduled by phone without prior seeing the vehicle. When it arrived… ... Please, see for yourself:
I've asked for 1 day and a half, and client promptly agreed.
281km (~120km was the distance between me and the client).
http://www.autogeekonline.net/galler...um/km-runt.png
Dealer Installed Swirl Option - The Before Pictures:
Hood DISO:
http://www.autogeekonline.net/galler.../hood-DISO.png
Roof DISO:
http://www.autogeekonline.net/galler.../roof-DISO.png
Side back pillar:
http://www.autogeekonline.net/galler...back_close.png
Trunk lid swirled and rear glass opaque, full of spots:
http://www.autogeekonline.net/galler...runk-glass.png
This is not the way your 'Brand New' car should look:
http://www.autogeekonline.net/galler...ertrunklid.png
Random deep Scratches:
http://www.autogeekonline.net/gallery/data/500/RIDS.png
Everything here starts with a solid basement, so let's do the wheels:
http://www.autogeekonline.net/galler...eelsbefore.png
Using what I call my 'Soapy APC':
http://www.autogeekonline.net/galler...el-APCsoap.png
Even after APC, some major contaminants kept stick to the wheels:
http://www.autogeekonline.net/galler...wheel-cont.png
Used a claybar to get rid of it (using a back and forth gliding movement and Soapy APC as lube):
http://www.autogeekonline.net/galler...forth-clay.png
Looking almost Good:
http://www.autogeekonline.net/gallery/data/500/done.png
Here's the wheel cleaned and coated with PBL Wheel Coating:
http://www.autogeekonline.net/galler...eel-coated.png
After doing the wheels (but before it's coating), I've washed the car using Detailer's Xtreme Foam
http://www.autogeekonline.net/galler.../320i-wash.png
The car was Clayed using Fine grade nanoskin wash mitt. Minimum (but existent) contamination had to be removed. No spot missed!:
http://www.autogeekonline.net/galler...0i-clayedA.png
http://www.autogeekonline.net/galler...0i-ClayedB.png
After Drying, I went after the engine bay. It was not very dirty, so I could clean it entirely and fast using APCs, Degreasers, applied spray wax to the inside painted parts and 303 Aerospace Protectant to plastic parts:
http://www.autogeekonline.net/galler...ulmachines.png
To polish this car, I've 'relied on Menzerna's Shoulder'.
I've used a Flex 3401, and choosing the minimum abrasive method to get the job done I've 'played' with orange, white and gray pads, coupled with 400, 2500 and 4000 Menzerna polishes.
http://www.autogeekonline.net/galler...ipadchoice.png
Most of time I've used PF2500 on a white pad.
Polish ongoing, this car design and paint were projected to reflect:
http://www.autogeekonline.net/galler...sh-ongoing.png
Look at this 'Chameleon like' reflex:
http://www.autogeekonline.net/galler...n-reflexes.png
Additional Details:
Glass before / after using Pinnacle Waterspot Remover:
*Pictures are not on good focus, but are the only I had:
http://www.autogeekonline.net/galler...dium/glass.png
http://www.autogeekonline.net/galler.../glassdone.png
Any 'screw' passes without being noticed. Look at the license plate screws before/after picture:
http://www.autogeekonline.net/galler...fore-after.png
I've cleaned the paint using Pinnacle Black Label Surface Cleansing Polish, and finished applying the PBL Coatings late at night. Finished, I went to sleep.
http://www.autogeekonline.net/galler...fore-sleep.png
When I woke up, I've faced the coated car in garage. Paint was reflecting just like glass.
http://www.autogeekonline.net/galler...tive-glass.png
I've then, respecting 12 hours of coating application, lightly washed the car (touch-less wash) to get rid of any dust and/or compounding dust that may be at the gaps. I've joined work with joy and took the opportunity to test the just applied coatings.
Coating: Water Beading, Sheeting, and Considerations.
I've used a very low concentration of Xtreme Foam Soap.
http://www.autogeekonline.net/galler...um/beading.png
Roof beading shot:
http://www.autogeekonline.net/galler...of-beading.png
Rear Glass and Trunk Lid, Beading!
http://www.autogeekonline.net/galler...ck-beading.png
Coated wheels, water beading:
http://www.autogeekonline.net/galler...el-beading.png
Hood, start sheeting to dry the car with minimum touch necessary:
http://www.autogeekonline.net/galler...d-sheeting.png
Just run a free flow of water, then...
http://www.autogeekonline.net/galler...-sheeting2.png
I could do even better if not in a hurry!
http://www.autogeekonline.net/galler...-sheeting3.png
One light towel pass and you're done with what was missing:
http://www.autogeekonline.net/galler...ting-dried.png
SUN shots:
(PS: At this point car was fully corrected and coated with PBL Surface, Paint, Glass and Wheel Coatings).
Hood under the sun:
http://www.autogeekonline.net/galler...m/hoodsun1.png
http://www.autogeekonline.net/galler...m/hoodsun2.png
http://www.autogeekonline.net/galler...m/hoodsun3.png
http://www.autogeekonline.net/galler...m/hoodsun4.png
Roof shot
http://www.autogeekonline.net/galler...m/roof-sun.png
Roof Closer (notice the flake pops)
http://www.autogeekonline.net/galler.../roof-sun2.png
Side spot Shot #nomoreswirls:
http://www.autogeekonline.net/galler...m/side-sun.png
Trunk and rear glass
http://www.autogeekonline.net/galler...rglass-sun.png
Another Spot on trunk
http://www.autogeekonline.net/galler...unklid-sun.png
This is so inviting for a ride... Interior was fully cleaned and vacuumed, interior trim was protected with 303 Aerospace Protectant.
http://www.autogeekonline.net/galler...m/ride320i.png
This is how a brand new car should look:
http://www.autogeekonline.net/galler...ium/done_5.png
http://www.autogeekonline.net/galler...um/done_13.png
Waiting for the owner to pick up her brand new 320i!
http://www.autogeekonline.net/galler...ium/done12.png
It was a great moment, and I'm happy I've met expectations on this job.
Thanks to AG and PBMG I have a respectable business card:
http://www.autogeekonline.net/galler...iness-card.png
Hope you enjoyed as much as I did, I'm already missing this beauty on my garage.
Questions, comments, critics, suggestions, always, always Welcome!
Thank you very much for watching.
Kind Regards.
Re: 2014 BMW 320i Full Pinnacle Black Label Coating
Excellent write up and pictures. It is quite remarkable how much damage was already on the new vehicle.
Did you just coat the face of the wheels?
Looks absolutely amazing! Fantastic job my friend:)
An amazing job. Looks great.
Amazing work and documentation as usual :dblthumb2:
Awesome work. I wish I knew how to detail like that.
Great work! Looks like glass. I have a c300 benz and it's black. I'm thinking going with BL coating. How do you like working with it? Also and issues with streaking?
Quote:
Originally Posted by
Hunter09
I'm pretty sure you'll love it!
