IGL Coatings here at Autogeek!
https://s.yimg.com/aah/autogeek/igl-coatings-9.gif
Safe for your car, safe for you, and safe for the environment!
When IGL was first created, it was founded on the premise that high-quality, professional grade car care products and eco-friendly car care products were not mutually exclusive. Each product that IGL formulates, tests, and manufactures is designed to maximize effectiveness while also maximizing both the user’s health and the environment’s health. Every proprietary formula IGL creates contains little to no VOCs (Volatile Organic Compounds) that are often used in car care products and have been proven dangerous to the environment and our health.
IGL never lets this focus on safety and health impact the effectiveness of the products they produce. IGL produces their products for use by professional detailers, so the results their product provide need to be of the highest tier. With more than 1000 IGL certified detailers across 52 countries, you can be sure that IGL as brand is trusted around the world by capable professionals!
Cleans, rejuvenates, and protects your paint!
IGL Ecocoat Wax is one of the most advanced waxes available on the market today. IGL Ecocoat Wax formulates 100% pure carnauba wax into a solid paste wax using nano-scaled silane and siloxane technology. The fillers contained in IGL Ecocoat Wax will be able to greatly improve the look of your paint by filling in the fine scratches and swirl marks on the surface. IGL Ecocoat Wax then creates a durable hydrophobic layer of protection that will repel water, oil, and dirt, making it extremely easy to clean the surface of your paint!
https://s.yimg.com/aah/autogeek/igl-ecocoat-wax-3.gif
IGL Ecocoat Wax
Our Price: $59.99
Protect your leather investment!
IGL Ecocoat Leather is a professional grade coating designed to protect what is probably the most sensitive material found in cars, leather. IGL Ecocoat Leather is specially designed to form cross-links with leather surfaces, creating an invisible, flexible layer that is virtually undetectable. IGL Ecocoat Leather will protect your leather from hazards such as liquid, dirt, dye, and UV radiation. IGL Ecocoat Leather’s breathable and non-etching coating will maintain the flexibility, appearance, and texture of your leather.
https://s.yimg.com/aah/autogeek/igl-...it-30-ml-3.gif
IGL Ecocoat Leather Kit 30 ml.
Our Price: $79.99
Looks out for your headlights so they can look out for you!
The IGL Ecocoat Headlight Kit will give you all the products and tools you will need in order to apply a high-quality layer of protection to your polycarbonate headlights. IGL Ecocoat Headlight is specially formulated to crosslink with polycarbonate to create a strong and lasting bond for up to 12 months. IGL Ecocoat Headlight will protect your headlights from the oxidation and yellowing that often plagues these surfaces. With a hardness rating of 6H once fully cured, you can be sure that IGL Ecocoat Headlight is fully capable of standing up to the hazards that threaten your headlights!
IGL Ecocoat Headlight Kit 30 ml.
Our Price: $50.99
Protect the investment you made on your wheels!
The IGL Ecocoat Wheel Kit is an all-encompassing kit that will give you all you’ll need to apply incredible, lasting protection to your wheels. IGL Ecocoat Wheel will create a barrier of protection on the surface of your wheels that will protect them from dangerous hazards. Once IGL Ecocoat Wheel is applied to your wheels, brake dust as simply be pressure washed off, saving you a ton of time on wheel cleaning. Once fully cured, IGL Ecocoat Wheel has a 9H pencil hardness rating, making it quite resistant to damage and wear!
https://s.yimg.com/aah/autogeek/igl-...it-30-ml-4.gif
IGL Ecocoat Wheel Kit 30 ml.
Our Price: $69.99
Prevents trim fade and degradation!
The IGL Ecocoat Trim Kit comes with every product and tool you will need to apply IGL Ecocoat Trim to your car plastic and rubber surfaces. IGL Ecocoat Trim is specially formulated to instantly bond with your trim surfaces on the molecular level to ensure proper protection and durability. Once cured, IGL Ecocoat Trim has a hardness rating of 6H that is sure to prevent damage from UV rays and other contaminants that cause premature fading. Thanks to the hydrophobic and dust-resisting qualities of IGL Ecocoat Trim, cleaning your trim will be worlds easier than it has ever been before!
IGL Ecocoat Trim Kit 30 ml.
Our Price: $49.99
Very resistant to wiper wear!
The IGL Ecocoat Window Kit includes all of the products you need to apply a durable and effective coating to your car’s glass surfaces. IGL Ecocoat Window is glass coating that will not only vastly increase the look of your glass surfaces, but will also improve the functionality of your glass as well. IGL Ecocoat Window makes your glass extremely hydrophobic, causing any water that collects on the surfaces to bead up and be easily removed. In fact, IGL Ecocoat Window makes your glass so hydrophobic that you won’t even have to use your windshield wipers at speeds of 30 MPH! Unlike most glass coatings, IGL Ecocoat Window is much more resistant to the wear caused by windshield wipers, greatly increasing the duration of the coating.
https://s.yimg.com/aah/autogeek/igl-...it-60-ml-3.gif
IGL Ecocoat Window Kit 60 ml.
Our Price: $72.99
Perfect for avoiding highspots!
IGL Coating Removal Towels are manufactured to ensure that you are able to buff off your coatings as effectively as possible after application. One of the biggest issues with the application of coatings is the risk of “highspots”. These occur when there are areas of the coating layer that are not even with the rest. IGL Coating Removal Towels have a shallow and sturdy nap that will ensure level buffing off, letting you enjoy a pleasant, defect-free application!
https://s.yimg.com/aah/autogeek/igl-...-10-pack-3.gif
IGL Coating Removal Towels 10 Pack
Our Price: $32.99
https://s.yimg.com/aah/autogeek/igl-...t-fabric-6.gif
IGL Ecocoat Fabric
Our Price: $89.99
https://s.yimg.com/aah/autogeek/igl-...-premier-6.gif
IGL Ecocoat Premier
Our Price: $66.99
https://s.yimg.com/aah/autogeek/igl-ecoshine-dash-6.gif
IGL Ecoshine Dash
Our Price: $17.99
https://s.yimg.com/aah/autogeek/igl-...enhancer-6.gif
IGL Ecoshine Enhancer
Our Price: $19.99
https://s.yimg.com/aah/autogeek/igl-...-leather-6.gif
IGL Ecoshine Leather
Our Price: $39.99
https://s.yimg.com/aah/autogeek/igl-...ne-paint-6.gif
IGL Ecoshine Paint
Our Price: $19.99
https://s.yimg.com/aah/autogeek/igl-ecoshine-tyre-6.gif
IGL Ecoshine Tyre
Our Price: $15.99
https://s.yimg.com/aah/autogeek/igl-...an-glass-6.gif
IGL Ecoclean Glass
Our Price: $15.99
https://s.yimg.com/aah/autogeek/igl-...interior-6.gif
IGL Ecoclean Interior
Our Price: $15.99
https://s.yimg.com/aah/autogeek/igl-ecoclean-iron-6.gif
IGL Ecoclean Iron
Our Price: $34.99
https://s.yimg.com/aah/autogeek/igl-...an-multi-6.gif
IGL Ecoclean Multi
Our Price: $19.99
https://s.yimg.com/aah/autogeek/igl-...-precoat-6.gif
IGL Ecoclean PreCoat
Our Price: $19.99
https://s.yimg.com/aah/autogeek/igl-ecoclean-tar-6.gif
IGL Ecoclean Tar
Our Price: $29.99
https://s.yimg.com/aah/autogeek/igl-ecoclean-wash-6.gif
IGL Ecoclean Wash
Our Price: $10.99
Re: IGL Coatings here at Autogeek!
Elliot I didn't see any paint coatings listed. Did I overlook?
Thanks,
ScottH
Quote:
Originally Posted by
ScottH
Thanks,
ScottH
IGL’s paint coatings are only available to the professional.
I wonder if IGL will come out with different levels of products like Meguiars. Right now the coatings are only for the professional but I wonder if there will be a coating line that most of us weekend guys can use.
I was wondering if the Ecocoat Wax is a coating infused wax like Kamikaze Infinity Wax or something similar.
It’s kinda hard to tell from the description.
