griots microfiber and pad cleaner during detail?
can u put some pad cleaner in a spray bottle and mist it on to clean pads in between panels on the fly?
Re: griots microfiber and pad cleaner during detail?
I would just get more pads.Or clean it on the fly how Mike Phillips tought with out any cleaner.
I would not, blowing out after each pass is better if you can.
use air or a small brush and fluff as you go. i normally change pads ever 2 panels and as I go I tend to spin them against a small brush to clean and fluff them as I move along.
Quote:
Originally Posted by
Mike lambert
i could set something up for that
I believe the pad cleaner would probably need to be rinsed from the pad and the pad dried before using again. I could be wrong though
Mantilgh
i think ur right im just going to clean it the usual way thanks
I usually use 3 pads to clean a midsize car.. I havn't personally tried this.. But maybe you can clean the pads then used the polisher at full speed to help dry the pads.
goldenlight
thats not a bad idea
Blow out with a compressor or use a pad brush after each pass.
