1 Attachment(s)
Help with 21ft 1991 Bayliner Trophy Boat Hardtop
Hiya fellas,
Looks like I'm about to make my foray into boat detailing--and how! As you can tell by my thread title, it's a 21 foot 1991 Bayliner Trophy Boat with a hardtop.
Here are some of the aspects pertaining to the boat that the client shared with me on the phone today:
- The Gel Coat is dull and hazy
- Gel coat is not terribly neglected, and doesn't have any obvious signs of severe age, swirls, or chips
- The botton hull portion of the boat is VERY dull and in need of extreme attention (he believes this is because it's the portion that sits in the water and has a special coating on it to resist the elements)
- He tried a test-spot, by hand, with 3M's "Marine Restorer & Wax" and was highly impressed by the results -- but is certain that for such a large vessel the boat would need to be tended to entirely by machine (I have a FLEX and a Makita)
So, with those little doodads in your noggin... hows about we tackle a couple questions to get my "sailing" in the right direction as I enter the realm of watercraft refinement, please:
- What product, or products (since I'll likely have to do a two phase polish/sealant) is ideal and time-tested as a proven performer in the aquatic world of gel-coats? (I know there is never a "best" product - I've been doing this for over a decade - but what would yield amazing cleaning and polishing/glossing results in one, or two steps with regards to a boat?
- What RPM should I use while polishing?
- For boats over 20 feet and with a hardtop, what is a usual approximation of a quote for just the exterior, and the exterior AND interior?
- Will I need a special sealant or wax to apply after compounding/polishing?
- Lastly, what type of pad(s) should I use? I have all types of foam, but can purchase some other materials if necessary
I imagine the project to be similar to: THIS from the description on the phone (he does not own a phone so he cannot MMS) I am also attaching an image to this post for reference.
A thousand thank yous!! I'm very excited to apply the techniques and methods from motorcycles and motorcars over to the boat crowd, mateys! Ahoy.
Re: Help with 21ft 1991 Bayliner Trophy Boat Hardtop
Bump, PLEASE!
I told the owner I'd have a quote to him BY TODAY! Please lend a hand.
Another bump for another new day... whew, today was a long one, doing a three-day detail on a 2014 Cadillac - looking so fine!
SO... ideas/ranges for a two-phase polish on a 21ft hard-top trophy boat?
use aquabuff 1000 and 2000 on a rotary with wool.
I'm no expert but this is what I use:
To remove heavy to medium oxidation use your Makita Rotary with 7.5" twisted wool pads and a water based compound (Farecla Profile 200 / Aqua Buff 1000 / Presta Supercut) first. If water based compound not working use a petroleum based compound (Fountain of Youth - Vibra Cut / Megs Heavy Cut / 3M). Twisted Wool and heavy cut compound will leave swirl marks. Rotary speed approx 1800 to 2200 rpm for heavy cutting.
To remove light oxidation or first step swirl marks use a blended wool/lambs wool/heavy to medium cut foam pad to create a good shine. Use lighter grit compound in same series as first pass. Rotary speed 1400 to 1800 rpm for light polishing.
Last pass I use a polymer sealant or a Carnuba wax (Collinite) - lots of options available. Apply by hand (sealants) or DA on slow speed (wax).
Thanks fellas!
Quote:
Originally Posted by
primo spaghetti
Sounds easy enough... I'll look into Aquabuff, obviously I've never heard of it since we're concentrated the area of our business focus on motorcars and bikes over the years - but this is another ecessary layer for business growth.
- Do any waxes or specialty products need to be applied after the two-stage compound and polish?
Chase_910
VERY NICE!! Thanks Chase :) So that answers my question from above, pertaining to a traditional LSP needed on a gel coat finish. So your system above requires a Makita (great, I have that) and some wool pads... looks like I'm ready to go aside from the products themselves.
Thanks for the help, the RPM speed was insightful.
So... do these nautical gel coat finishes haze or hologram like clear-coats?
Ohio Detailing
I'm getting ready to make my order... what size bottles am I looking for in order to polish an entire 21 foot hardtop Bayliner trophy boat?
:buffing:
Would any of these be ideal, if the boat only has light to medium oxidation?
1. Marine 31 All-In-One Gel Coat Polish and Wax, all in one boat polish wax, boat cleaner wax
2. Marine 31 Gel Coat Gloss and Color Restorer, marine compound, gel coat oxidation remover, fiberglass restorer
3. Meguiars #50 Marine/RV Cleaner Wax is a polish and wax in one for your fiberglass, gel-coated boat or RV.
4. 3M Marine Restorer & Wax, boat polish and wax, boat wax, fiberglass restorer, gel coat polish
5. Collinite Fiberglass Boat Cleaner #920
It isn't severe enough to need a heavy cut, and I'm having issues finding Aqua Buff 1000 on AutoGeek.
