Re: White spots on paint?
Did you try to simply pick them off with your fingernail?
Also - because this is your first post,
Welcome to AutogeekOnline!
:welcome:
Thanks Mike - good to be here!
I haven't - before i clayed i could tell they were rough but couldn't tell if they were below or above the surface. I was worried of doing more damage than good by trying to scrape them off.
A panel beater mate (before i noticed all of these), looked at two i have on the front of the car and said they are rough so are chips. I haven't clayed these ones on the front yet so they may be chips, or they might just be the same as the others.
I guess i will try pick them out (the ones i have clayed) with a tooth pick or something?
Thanks
Quote:
Originally Posted by
Mike Phillips
:welcome:
You are a genius Mike!
i clayed a few of the spots again, sprayed some bug and tar remover on and let it sit for a bit. Buffed it off... they were still there. I got a tooth pick and slowly scraped at them and they started to fall away...
Im the MAN
Must be dried product of some sort.
Thanks!
Hi and welcome to the forum.
I would've thought that Claying would've gotten this problem rectified, but perhaps the clay you used was on the mild side, or not used enough? Glad to hear that it does appear to be on top of the paint, and not in the paint.
I'd likely reach for a more aggressive clay first, and not try to resort to a more aggressive polish to remove them.
Optimum sells a more aggressive Black Clay here, this might be the ticket?
rover137
There's plenty of people that will disagree with you. :laughing:
rover137
Just guess on my part but from your description and the appearance, it must have been "something in the air".
A fingernail, popsicle stick, plastic razor blade, old credit card, room key card, etc.
Sometimes, the keep it simple simon approach gets the job done.
MarkD51
Hi MarkD51
I used Mequiars clay and detail spray for this. I have read that it is quite a mild clay but i originally bought it as the car was only 1.5 months old when i first got it (3 weeks ago) and clayed it.
Thanks for that - i might see if i can that somewhere here in Aus for the rest of them. I had a look but can't seem to find it online. The only clays available in auto shops here are Bowdens, Mothers and the Mequiars i already have. I found this which seems to be more aggressive but not too heavy duty - Clay Magic Red Clay Bar (Medium) 200gr | Car Care Products Australia
Yeah, I thought it odd that whatever the spots are survived multiple and extensive clays, detail sprays, bug removers and around 4-5 washes.
After i got rid of the 2 on the front (which a guy at a bodyshop swore were chips :/), i noticed what appears to be a scratch/chip in the clear coat. Not at all rough so again - hard to tell. it is silver rather than white and jaggered edges in appearance rather than white and circular like these ones. Maybe this one can be polished out.
